My screen washers seem too low. They hit the bottom of the screen and get masked by the wipers. I looked at them for adjustment but they seem llike a moulded plastic assembly. Is there any adjustment or are they designed into that position?
Open the bonnet and if you look carefully, you'll see a screwdriver type slot in the side of the jet. This is where you adjust the level for your jets. Be CAREFUL though, as there is very little adjustment that can be made here ..
Hi,
I found the slots you mention which are acually snail cam adjusters. Very posh but even with them adjusted,I still can't get enough angle to miss the wipers in the rest postion. I checked the wipers and they apper to be parked correctly on the screen. Someone suggested putting a pin in the jets and moving them but they look like a non adjustable moulding to me.
