Fault codes
nickaudi41
Hi everyone,
I ran VAGcom and got the following:
Address 01: Engine
Controller: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 06435
WUAZZZ8DZ1N901949 AUZ7Z0Y1578245
1 Fault Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 00899
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
Thanks in advance
Kind Regards
Nick
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
  • Malfunction Indicator Light (MIL) active
Possible Causes
  • Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
  • Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
  • Evaporative Emission (EVAP) Canister Sealing faulty
  • Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
  • Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
    • Perform Output Test
  • Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
    • Perform Basic Setting
  • Check Pipes between Tank Breathing and Throttle Body #
01435 - Brake Pressure Sensor 1 (G201): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Possible Causes
  • Basic Setting not performed
Possible Solutions
01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
  • Brake Pedal Switch (F) faulty/jammed
  • Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
  • Check/Replace Brake Pedal Switch (F)
    • See Measuring Blocks
  • Check/Replace Brake Pressure Sensor 1 (G201)
    • ABS Hydraulic Unit (N55) may need to replaced
    • Perform Brake Pump Bleeding
    • Perform Brake Pressure Sensor 1 (G201) Basic Setting
    • Replace Brake Electronics Control Module (J104)
Retrieved from "http://wiki.ross-tech.com/index.php/01435"
Hi Nickelvery - did you come to a solution for the EVAP code?
the same one has cropped up on my S3 this week.
Do you have any issues with your fuel flap? i.e you get a hissing sound of the pressure being released when undoing the the fuel cap?
nope i dont get any noise when opening the fuel flap.
what would that indicate out of interest?
It would indicate a ******** gravity valve in the fuel tank, meaning a fuel tank off job to get to it.
But you haven't got that so all is good!!
On the EVAP issue, have a look around the canister to see if any leakages are there.
certainly will do.
..... erm wheres it located?!
you needing an RS3 badge by the way - just noticed your sig and I've got one kicking around the garage thats still in the packet
Next to the Power Steering Fluid container it has the hoses coming out of it.
Unforunately not as I haven't got an RS3 yet and I doubt I ever will, then again you never know!
10
3K
chazza55
C
