Bluetooth Help!
magnus911
R8GGA
Fulham
Website
www.it-tronics.co.uk
Ok, little problem...
I bought a 8P0 862 335 D telephone unit off ebay (yes I know it's limited functionality...) and a cable from Kufatec so I could hook it up to my RNS-E..
I did the install this morning, and am happy that all the wiring is correct and I've plugged in the aerial etc.
I am also confident that the RNS recognises the unit because when I push 'tel' button, instead of saying 'telephone not available' it now says something along the lines of 'when you receive a call you can answer it using the jog dial...'
Only problem is I can't see it on my phone. I've tried my phone (blackberry 8100), a mate's Nokia, another mate's Motorolla and still nothing.
I've tried it at all times too, ignition on/off, unit just turned on, unit rebooted and still can't see anything.
Is this just a duff unit or am I doing something wrong?
Any help much appreciated.
Magnus
You may have already tried this but worth a mention.
The car will only send out a Bluetooth search signal for around 3-5 mins.
You need to do a device search on your phone within this time from the moment the ignition is turned on.
Also...may seem daft and i apologise if its obvious but it may be listed as an "audio enhancement" rather than a "device"
I am the accessory guy at an Audi dealer and i'm pairing mobiles for people EVERY day and i gotta admit i have never encountered this problem. I would be inclinded to double check/triple check the wiring buddy.:icon_thumright:
Thanks Cal but I know that it'll only be discoverable for the first few minutes so I've been trying that...
Also, the RNS definitely knows it's there because otherwise the text in the 'tel' option wouldn't have changed...and if it's getting power then the bluetooth should turn on!
If you're doing these all the time, do you have much experience with this particular unit? Do you know if it's just not compatible with any phones?
thanks...
compatability has always been a grey area.
If Audi haven't got round to physically testing specific models, they wont add it to there list. This doesnt always mean they wont work so there is no definate "yes" or "no" answer.
One thing that does ring alarm bells for me is that it doesnt seem to work with ANY of the phones you've tried. So that eliminates phone fault.
Another daft question and again apologise in advance, but do the other phones "find" each other via bluetooth?
without stating the obvious, it does sound like you have a fault/ wiring issue.
You are doing everything else right, in the right order and seem to know what your doing.
99.99999999 times out of 100 pairing mobiles to in car bluetooth is a breeze....so easy in fact that customers think im some form of miracle worker. Which makes me think you have a fault somewhere rather than user error. I think when you sort it you'll see what i mean, it is so so easy its embarressing!
It may need switching on, bt enabled.
You will need VAG-COM to check/modify this.
Select]
[77 - Telephone]
[Adaptation - 10]
Channel 133
[Read]
0 = Bluetooth OFF
1 = Bluetooth ON
[Test]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Hands Free Function
[Select]
[77 - Telephone]
[Adaptation - 10]
Channel 134
[Read]
0 = Hands-free active while Bluetooth connection is active but without cell phone engaged
1 = Hands-free only active with cell phone engaged
[Test]
[Save]
[Done, Go Back]
Craig,
thanks for the suggestion - if you remember you sent me a pm last week telling me to vagcom the following:
"It will work sort of, code your RNS-e to 0xxx2xx"
Is that not enough? I got the technician to do it when my car was serviced this week...
thanks for all your comments guys!
I recently helped a chap who had bought a brand new bluetooth module form a dealer and couldn't get it working (neither could the dealer).
I was all down to channel 134 being set to 1 and not 0.
Basically if it is set to 1 then the bluetooth only works if your phone is docked in a cradle. As you don't have a cradle you need to change it to 0 and then it should work.
However you may still have problems as the D version is well known to have very limited phone support.
So, have you checked out the values of the adaption channels quoted above? I think there is a good chance this might solve your problem, failing that it might me due to the limited functionality of the 'D' revision interface.
Could be time to throw it on Ebay and try a later unit?
Thanks for all the suggestions - sounds like it could well be that setting which is preventing me from using it...but I'll have to wait until I can get my hands on a VAG COM cable before I can do it! There's a chap local to me (friend of a friend) who i've left a message for but no word yet so I'll let you know how it goes! THanks again!
You legends! Thanks, it was that channel setting...and also the guy who serviced it turned out not to have coded the RNS properly...and I had bent some pins when installing the mic but now it all works properly!
THanks!
13
740
NHN
