Selling my low mileage mk1 Audi TT quattro low mileage 5 former keepers, MOT 28th Oct 2024 , FSH the engine has had an oil change every 5000 miles since it left the factory in 2002, spend £1000s getting the car to a high standard, the body work is in good condition & i've had new sills & wings fitted to get the car looking fresh
Eibach B12 pro kit suspension upgrade & new top mounts, adjustable rear camber arms
V6 front brake callipers installed & fluid flush
Gates timing belt kit & engine serviced (64883 miles)
V6 front bumper including new sills & wings
Carbon spoiler extension & honeycombe resr diffuser
Brand new front subrame fitted, new front driveshafts, new wheel hubs & abs rings
Front wheel bearings replaced & abs sensors
New lambda sensor & 3 inch stainless downpipe with decat pipe from Germany (have the catalytic converter fitted to the car but decat pipe can be swapped over)
The exhaust is a custom stainless but sounds like the standard factory spec
New oil pressure switch, new thermostat, coolant temperature switch, new aluminium coolant pipes & coolant flush & change
Rear drop links installed & trailing arm bushes require replaced have this job booked in this week
Wheels refurbed professionally & new centre caps i found on ebay to give original rims sportier look ( have original centre caps)
New upgraded wiper motor fitted
I've probably forgot other items & i've replaced many nuts & bolts with genuine Vag parts
Looking for £5000ono
