Space saver
paddyirishman
Ireland
Hi guys. Hate the thought of not having a spare wheel in the car. Is there a part number for a spare wheel for a 2020 S4 Tdi?
Tyres on the car are 255/35/19 so the spare needs to have the same rolling diameter? (First quattro car... )
Think I might have sourced a space saver. 125/80/r18 - 5x112 - ET0.
It has a rolling circumference of 2063mm (standard car wheel is 2076mm). Not a big difference but is it enough to cause problems?
The tyre pressure sticker on your door will give you the size of wheel/tyre you need. The S4 has larger brake discs so IIRC you will need a 19” spacesaver. 8W0601027B T125/70 R19 tyre.
Reactions: paddyirishman
No sticker on the door unfortunately, must have been removed by the previous owner...
I have a space saver in boot let me look tomorrow.
Sent from my CPH2025 using Tapatalk
Yes you can get one from a dealer but expensive. Plenty on eBay, the one I bought from there was as new, just a bit of dust on it!
Be careful as the S4 TDI has 375mm discs compared to the 349mm on the S4 petrol.
Just keeps getting more complicated!
The 19" rim should clear the discs though I hope?
I would say so as the part number for the S4 spare is the same as the one for the RS4 which also runs 375mm brake setup.
4,00BX19H2ET22 rim with T 125/70 R 19 tyre
Sorry for late reply. Thus is the space saver from a 2017 s4
Tyre says T125/70R19 100M on the side wall.
Hope this helps
Matt
