Q7 Battery issue? Deeper issue? Jump start everyday!
stanny2k
UK
Hi all,
So, long story short - For the past 6 weeks, I've had to jump start my car almost every morning (I'm using a NOCO GB40 1000A Jump Starter)
I've taken the car to the garage who tested the battery and it's fine. They said it was 40% charged, so they charged it, but a day or so later, the issue is back.
I've just bought a CARISTA OBD2 scanner and these are the results - I'm hoping someone has a bit more knowledge than I do that would possibly be able to point me in the right direction to pin-pointing the issue.
I did 3 scans on the car...
Car Scanner ELM OBD2
DTC report
Selected brand: Audi
============1==============
1207
Raw code: 04B7
ECU: 19. CAN Gateway
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Auxiliary heater control unit-J364
============2==============
1826
Raw code: 0722
ECU: 03. ABS control unit[Archive (inactive)]
Status: Validated and stored in non volatile memory
Audi: B169329: Right front treble speaker motor
Implausible signal
Audi: C119811: Low beam light bulb
Short circuit to Ground (GND)
Audi: Steering angle sensor-G85, supply voltage on cell 30; Steering angle encoder G85, KL30 power supply; Gearbox output speed sender G195 no signal
============3==============
5663
Raw code: 161F
ECU: 01. Engine control unit
Status: Pending fault present, Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: B13CEF2: Multimedia system control head
Button for traffic band
Audi: Glow plug cylinder 6-Q15 open circuit
============4==============
5481
Raw code: 1569
Status: Pending fault present, Validated and stored in non volatile memory
Audi: Switch for GRA-E45 implausible signal
============5==============
5658
Raw code: 161A
Audi VAG other; A1 2019; A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A3 2020; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; VAG other; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; A8 2018; Q7 2016; R8 2015: P119A00: Fuel pressure sensor
Malfunction
Audi A1 2019; A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A3 2020; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; VAG other; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; A8 2018; Q7 2016; R8 2015: B1291FD: Multimedia system control head
Button for main menu "MENU"
Audi: Glow plug cylinder 1-Q10 open circuit
============6==============
2401
Raw code: 0961
ECU: 05. Authorization system for access and starting the engine
Status: Pending fault present during this driving cycle, Test conditions are met, Validated and stored in non volatile memory
Audi: U14BB00: Front passenger door control module
Signal not qualified
Audi: Terminal 75x; Clamp 75x
============7==============
0532
Raw code: 0214
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory
Audi A1 2019; A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A3 2020; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; VAG other; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; A8 2018; Q7 2016; R8 2015: B13A401: Speaker channel 5
Electrical error
Audi A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; R8 2015: B11A201: Hydraulic pump relay
Electrical error
Audi VAG other; R8 2015: B106C13: Subwoofer
Open circuit
Audi VAG other: B145613: Left front treble speaker 2
Open circuit
Audi R8 2015: B15E413: Front left head-rest loudspeaker 1
Open circuit
Audi: Supply voltage
============8==============
0446
Raw code: 01BE
Audi: B105000: Function limitation due to excessive temperature
Audi: Work restriction due to insufficient voltage; Functional restriction due to undervoltage
============9==============
2259
Raw code: 08D3
ECU: 07. Head unit controller (VW TP2.0)[Archive (inactive)]
Audi: Display for front control panel, display and information display-J685; Display unit for control unit display and control unit front-J685
============10==============
0658
Raw code: 0292
Audi VAG other; A1 2019; VAG other; R8 2015: C109C07: ASR/ESP button
mechanical malfunction
Audi A1 2019; A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A3 2020; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; A8 2018; Q7 2016: B18E3F1: Speaker channel 5
Acoustic error
Audi A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; A8 2018; Q7 2016: C11F629: Sensor for swivel module position
Implausible signal
Audi VAG other; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; Q7 2016: B145600: Left front treble speaker 2
Audi: Control Panel; Control unit; Injection valve cylinder 11-N301 short circuit to positive
============11==============
0446
Raw code: 01BE
ECU: 08. Heater and climate[Archive (inactive)]
============12==============
2095
Raw code: 082F
Audi: U112300: Databus error value received
Audi: Component Protection Enabled; Component protection active
============13==============
0446
Raw code: 01BE
ECU: 0E. Media player 1
============14==============
0532
Raw code: 0214
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============15==============
0446
Raw code: 01BE
ECU: 16. Steering column
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
============16==============
2072
Raw code: 0818
Audi: U14B800: Front driver door control module
Signal not initialized
Audi: Power Management System Control Module-J644; Energy management control unit-J644
============17==============
0532
Raw code: 0214
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============18==============
0532
Raw code: 0214
ECU: 17. Dashboard
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============19==============
1583
Raw code: 062F
ECU: 34. Ride height control system
Status: Validated and stored in non volatile memory, Validated fault present at time of request
Audi: B161511: Microphone 3 for noise reduction
Short circuit to ground
Audi: System leak detected; Leak detected in the system
============20==============
1772
Raw code: 06EC
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
Audi: Signal wire from pressure sensor for ride height control-G291; Signal line from level control pressure transmitter-G291
============21==============
1769
Raw code: 06E9
Audi: Front Right Level Sensor-G289; Front right vehicle level sender-G289
============22==============
0776
Raw code: 0308
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi A1 2019; A3 2013, Q2 2017, A3 USA/ CAN 2013, TT USA/ CAN 2015, Q3 2019, TT 2015; A3 2020; A4 2016, A5 2017, Q5 2017, A4 USA/ CAN 2016, Audi A5 USA / CAN 2016, Q5 USA/ CAN 2017; Q8 2018, A6 2018, A7 2018, A6 USA/ CAN 2018, A7 USA/ CAN 2018, Q8 USA 2019 >, e - tron 2019 > e - tron USA 2019 >; A8 2018; Q7 2016: U163D00: Android Steuergerät
Keine Kommunikation
Audi R8 2015: B119112: Convertible top latch -open- switch
Short circuit to B
Audi: C10EF04: Signature light bulb
Faulty
Audi: Front Left Level Sensor-G78; Front left vehicle level sender-G78; Cyl. 8 misfires recognized
============23==============
0446
Raw code: 01BE
============24==============
1400
Raw code: 0578
Audi: Ride height control system; Level control
============25==============
1398
Raw code: 0576
Audi: Central locking signal wire: doors open; Signal line from central locking: doors open
============26==============
0446
Raw code: 01BE
ECU: 37. Navigation system
============27==============
2927
Raw code: 0B6F
ECU: 37. Navigation system[Archive (inactive)]
Audi: Error reading DVD; DVD read error
============28==============
1699
Raw code: 06A3
ECU: 46. Central comfort systems module (VW TP2.0)
Status: Pending fault present, Test is inhibited by other DTC, Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: Central locking electric motor in the luggage compartment lid-V53; Motor for central locking, tailgate-V53
============29==============
0870
Raw code: 0366
ECU: 47. Acoustic system
Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
Audi: B119613: Switch for convertible top compartment cover lock unlocked
Open circuit
Audi: Subwoofer, front left-R21; Front left woofer-R21; Camshaft position sensor => encoder G300 implausible signal
============30==============
0420
Raw code: 01A4
Audi: Mid-range speaker, front right-R104; Mid-range loudspeaker, front right-R104
============31==============
0871
Raw code: 0367
Audi: B119612: Switch for convertible top compartment cover lock unlocked
Short circuit to B
Audi: Subwoofer, front right-R23; Front right woofer-R23; Camshaft position sensor => encoder G300 signal too small
============32==============
0419
Raw code: 01A3
Audi: Mid-range speaker, front left-R103; Mid-range loudspeaker, front left-R103
============33==============
2246
Raw code: 08C6
Audi: Center speakers; Speaker center
============34==============
2558
Raw code: 09FE
Audi: Two-way speaker (mid and bass), rear left-R159; Mid-bass loudspeaker, rear left-R159
============35==============
2559
Raw code: 09FF
Audi: Two-way speaker (mid and bass), rear right-R160; Mid-bass loudspeaker, rear right-R160
============36==============
0532
Raw code: 0214
ECU: 56. Head unit (MMI) (VW TP2.0)
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============37==============
0446
Raw code: 01BE
============38==============
3041
Raw code: 0BE1
ECU: 61. Battery Regulation using CAN (VW TP2.0)[Archive (inactive)]
Audi: Energy management active
============39==============
2256
Raw code: 08D0
Audi: Quiescent current
============40==============
0532
Raw code: 0214
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============41==============
2072
Raw code: 0818
ECU: 6D. Tailgate/Boot lid
============42==============
2242
Raw code: 08C2
Audi: Button for closing the rear door in the luggage compartment-E406; Button for closing the tailgate in the trunk-E406
============43==============
0532
Raw code: 0214
ECU: 6F. Comfort system central module 2
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
============44==============
1626
Raw code: 065A
ECU: 76. Parking assistant
Status: Pending fault present, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Audi: B161513: Microphone 3 for noise reduction
Open circuit
Audi: Front Right Parking Assist Sensor-G252; Front right parking aid sender-G252
============45==============
1547
Raw code: 060B
Audi: B2008F0: Function restriction
due to excess temperature protection
Audi: Rear Right Center Parking Assist Sensor-G205; Rear right center parking aid sender-G205
DTC report
1207
Raw code: 04B7
2072
Raw code: 0818
0532
Raw code: 0214
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
1583
Raw code: 062F
0776
Raw code: 0308
Keine Kommunikation
Short circuit to B
Faulty
1699
Raw code: 06A3
DTC report
1207
Raw code: 04B7
0532
Raw code: 0214
Electrical error
Electrical error
Open circuit
Open circuit
Open circuit
1583
Raw code: 062F
0776
Raw code: 0308
Keine Kommunikation
Short circuit to B
Faulty
1699
Raw code: 06A3
3041
Raw code: 0BE1
Additional to this...
After clearing the codes I got the following errors on screen:
LOW BATTERY - DRIVING THE CAR WILL CHARGE THE BATTERY
ESP / ABS FAULT
Hope someone can help.
Thanks in advance
Out of interest, how old is the battery? How old is the car?
Remember with the battery flat, you're going to have all sorts of issues logged which are not genuine issues - In actual fact, my 12v battery in the e-tron had gone fairly low a few weeks back and I could not even open the door from the inside - scanned the car and had a whole load of errors from braking system to door modules etc.
Charged the battery using a ctek over the day/night and its not happened since.
Would be good to also know what the SOC for the battery is...
Could be something as simple as a bad battery to maybe a battery drain somewhere?
Have you got any accessories plugged in (dashcams, your Carista, cig lighter chargers etc)
Hi mate,
Firstly, thanks for the reply!
The car is a 2007 Audi Q7 - The battery is less than a year old - BOSCH from Eurocarparts.
As mentioned originally, the garage I took it too, charged it, but only for around 15mins. I dont think it was enough personally.
Will the ODB2 give me the SOC? If so I'll go scan that again now.
I dont have any accessories plugged in. I do have an Apple Car Play system, but thats always been there. Never caused me issues before. I say "always" - I had it installed around a month after buying the car (2 years ago) - These battery issues have been happening around 6-8 weeks.
It all started from when I used the car to jump start my work van once. May be a coincidence, but it just seems to have gotten progressively worse.
And is the battery to spec in terms of power etc? Sorry I've just seen it before where the battery was under-powered but only really showed when the temps dropped!
Charge: Unsure what they used but mine took hours to get up to a ready and charged state - can't see 15 mins being enough but others are probably more clued up on this
SOC: Unsure about Carista, I know VCDS does as I ran it many time son my old 2008 A6 which I see as being the same family as the 2007 Q7.
Yeah, it's definitely the right battery for the car. I've had that checked.
To be honest, for the sake of £79.99 for a CTEK charger, I might give that a go.
I'm going to see if the Carista has the battery level details now and report back.
Nah ODB2 doesn't show battery levels. Not on the 2 apps that I've tried anyway.
I'll give charging the battery a go and see if that resolves anything
15 minutes might put amp or two in but realistically a full charge will be 8 hours or more with a half decent charger. Carista on some vehicle’s now does live data so it might be worth seeing what your alternator is doing if that’s an option as it may be on its way out. This won’t necessarily show up on Carista unfortunately
15 minutes to get a battery up isn't nowhere near enough, ctek takes a day or so to get to the 8th stage of charging which includes maintenance work so to speak.
If batteries young then maybe look at the alternator as unless the battery has had some reverse load that's damaged from the jump start, it's unlikely that, but it can also happen so don't discount the battery just yet.
Right, I've fully charged it with the CTEK over night. Everything was successful.
Started first time and it's been fine driving today.
I won't be driving it now until tomorrow morning, so that'll be the true test for me.
Update...
Attempted to start the car this morning and it's dead :-( Will not start.
Battery is dead again. So something is CLEARLY draining that battery overnight.
Jump started it using a NOCO Boost Plus GB40 - Started straight away when this was connected, didn't even struggle!
So, I've cleared all fault codes and run a fresh scan when the engine is running and these are my results:
Detailed ECU info
ECU info obtained with Carista 711099 for iOS:
VIN: WAUZZZ4L17D087249
CAN network gateway
Part #: 4L0910468
Component: J533__Gateway
Software version: [none]
ASAM/ODX identifier: [none]
Coding: F75BBE5F302202 (hex)
Fault codes:
01207 Control Module for Auxiliary Heater (J364)
Engine
Part #: 4L0910401M
Component: 3.0L V6TDI G000
Coding: 11775 (decimal)
[No fault codes]
Transmission
Part #: 09D927750FS
Component: AL 750 6A
Coding: 504 (decimal)
[No fault codes]
ABS
Part #: 4L0910517A
Component: ESP ALLR
Coding: 38017 (decimal)
Fault codes:
01826 Sensor for Steering Angle (G85), Voltage Supply Terminal 30
Steering wheel
Part #: 4F0910549
Component: Lenksäulenmodul
Coding: 102042 (decimal)
[No fault codes]
Airbags
Part #: 4L0910655B
Component: 31 AIRBAG AUDI8R
Coding: 13105 (decimal)
[No fault codes]
Instrument cluster
Part #: 4F0910930C
Component: KOMBIINSTR. M73
Coding: 2593448 (decimal)
[No fault codes]
Infotainment display
Part #: 4L0910731C
Component: Interfacebox
Coding: 2002 (decimal)
[No fault codes]
Navigation
Part #: 4E0910887T
Component: MNS ECE
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Component: TUNER EU/US/RDW
Coding: 1 (decimal)
[No fault codes]
Sound system
Part #: 4L0910223E
Component: DSP-AU716-RD
Software version: 0130
Coding: 030000 (hex)
[No fault codes]
Media player
Part #: 4L0910110A
Component: MP3-Changer
Coding: [none]
[No fault codes]
Heater & air conditioning
Part #: 4L0910043
Component: KLIMABETAETIGUNG
Coding: 1046 (decimal)
[No fault codes]
Auxiliary heater
[ECU not present]
Parking sensors
Part #: 4F0910283G
Component: Parkhilfe 8-Kan
Coding: 211046 (decimal)
Fault codes:
01626 Sensor for Parking-Aid, Front-Right (G252)
Auto-leveling suspension
Part #: 4L0910553C
Component: LUFTFDR.-CDC
Coding: 15520 (decimal)
Fault codes:
01772 Signal from Level Control Pressure Sensor (G291)
01583 Leak in system recognised
00776 Level Control System Sensor - Left Front (G78)
Central electronics
Part #: 4F0910279K
Component: ILM Fahrer
Coding: 10101 (decimal)
[No fault codes]
Central electronics 2
Part #: 4F0910280
Component: ILM Beifahrer
Coding: 11101 (decimal)
[No fault codes]
Body/convenience system
Part #: 4L0910289D
Component: Komfortgeraet
Coding: 7348475 (decimal)
[No fault codes]
Part #: 4L0910290
Component: ILM HINTEN 2
Coding: 1 (decimal)
[No fault codes]
Driver's door
Part #: 4L0910793B
Component: TSG FA
Coding: 2651 (decimal)
[No fault codes]
Front passenger's door
Part #: 4L0910793B
Component: TSG BF
[No fault codes]
Rear left door
Part #: 4L0910795B
Component: TSG HL
Coding: 2058 (decimal)
[No fault codes]
Rear right door
Part #: 4L0910795B
Component: TSG HR
[No fault codes]
Trunk
Part #: 4L0910945
Component: ValeoHeckdeckel
Coding: [none]
[No fault codes]
Ignition authorization
Part #: 4F0910852
Component: FBSAUDIC6 ELV
Coding: 147 (decimal)
Fault codes:
02401 Terminal 75x
Battery regulator
Part #: 4L0910181
Component: J0644 BEM
Coding: [none]
[No fault codes]
Trailer
Part #: 4E0910383C
Component: ANHAENGERELEKTR
Coding: 1 (decimal)
[No fault codes]
Adaptive cruise control
[ECU not present]
Lane-change system
[ECU not present]
Lane-maintain system
[ECU not present]
Back-up camera
[ECU not present]
Obtained with Carista 711099 for iOS.
it’s so frustrating, when the car is running it drives like an absolute dream!
Anyone have any suggestions at all? Close to scrapping the thing! :-(
I think I’ve found what’s causing the drain. But I don’t know what it’s called or what it actually is.
Last night I got in the car to run some more tests, it was late and quiet outside (I live on a busy road)
I could hear, what sounded like a fan coming from the passenger side footwell. Upon further investigation (my sticking my ear/head closer and closer to where the noise is coming from)
I’ve got out of the car and listened closer to the front passenger wheel and the noise is definitely coming from behind that wheel. It’s almost as if it’s a high pitched noise that’s trying to constantly do something.
Looking back at the errors I’m getting, I remember seeing this one:
Part #: 4L0910553C
Fault codes:
Even though the engine is completely off and had been for over an hour this noise is still there.
Im not sure if anyone knows what would be behind that wheel but I’m thinking maybe it’s something to do with the ride height mode constantly trying to adjust. Just seems a bit strange without the engine on that’s all.
This seems to be the part - https://tinyurl.com/ya9xuejw
Any feedback would be greatly appreciated.
5K
NHN
