Q7 Terminal 30-3 Open Circuit U1413
Davus
Melbourne
Hi All,
Moving on from the previous errors i was getting around my distance sensors (got audi to recalibrate them), Im now just left with one fault that i cant seems to clear, not can i find much information on.
Appreciate if anyone can help find the cause. All fuses have been checked and tested. No problems there.
Address 09: Cent. Elect. Labels: Redir Fail!
Control Module Part Number: 8W0 907 063 G HW: 8W0 907 063 G
Component and/or Version: BCM1 MLBevo H12 0215
Software Coding: 07501943C12900CD010D06115B3F08F9130331008000000000 00000060001C810A4502AB22B70A
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 014003 (AU73)
ROD: EV_BCM1BOSCHAU736_014.rod
VCID: 3FDB4D08D7FFCF73F65-806A
1 Fault Found:
65560 - Terminal 30-3
U1413 00 [009] - Open circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Mileage: 154234 km
Date: 2022.09.01
Time: 13:18:59
average_Voltage_terminals: 12.10 V
Outside air temperature sensor-Resistance: 394.24 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 16.00 °C
interior_temperature: 19022.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
