Tyre pressure display
Robcobras
HULL
Hi, I've been flicking through menus and I can't find it.
Last night tyre pressure warning light/message came on. My previous car (insignia) had a function in the menu to show a diagram of the car with pressures for each tyre also ability to change depending on towing etc. Does the audi or is it a secret
Rob
Depends if its per wheel sensor based or abs based which doesn't display any pressures & generally doesn't show which wheel its detected anomalies on, best to ask audi to check your spec as to which version you have fitted, the pr code list is usually on a sticker in the boot, but they may have stopped doing this now for newer cars, once you have the codes you can look online to see what they represent or of course ask a dealer to check.
Pretty much all B9/9.5 apart from RS have indirect TMPS (poor mans version).. so no pressure measurement display . I have a list £68K S5 (b9.5) and was astounded to see the cost cutting on this level of car ..
Reactions: Sibmets
25
5K
19
11K
3K
3K
