S-Line 3.0tdi quattro rear coil springs
benali
Hereford
Both rear coil springs snapped on 57 plate 85k miles, one side stting about an inch lower atm.
OEM is is sachs I believe. £140/pair at euro.
S-line is probably different length to standard is it?
Anyone bought these recently at a good price?
Ye standards are a longer spring I’m in the trade £60-£75 per spring is the normal on rear A4’s A6’s buy good quality they do last
Reactions: benali
Trying to get a quote to fit these. Does anyone know the book time.
I guess, being quattro its a bigger job?
With above spring compressor which I’ve got take bottom shocker bolt out to give you a bit more flex approx 30-45 mins per side can do it with wheel on car just watch the bottom plastic guard that keeps the dirt out of the bottom of the spring
Reactions: benali and madstaff
buy brand name cialis online instructions for cialis use
Have you got oem number, some sites dont seem to differentiate between standard and s-line model.
Or do you know spring length, 2008 cab s-line quattro 3.0, rear spring?
You will probably find in the aftermarket that there is only a handful of different springs to suit the intended application.
Got to Audi/TPS for genuine and there will be different springs depending on the car being petrol/diesel, FWD/4WD, saloon/avant, etc, etc.
Get some H&R springs to upgrade. Eibach don't do them for a quattro, but I paid about £150 for the set of 4.
Don't bother with S line springs they're awful.
Eibach pro kit will fit the Quattro - E10-15-003-12-22
Can be found on amazon.de. .
