2011 Multi-tronic Reverse Woes....
dibbers
Wakefield
hi, as above. when reversing uphill in a field tonight, car accidentally wheelspan in the wet - then was suddenly very rough akin to "running on 3".
idles fine in park or drive, and managed to drive 30odd miles home fine.
reverse remains very coarse but everything fine and no warning lights.
any ideas?
thanks in advance.
car is a 2011 avant 2.0d (170), 180k.
hi pal thanks for reply - not sure on gearbox, i bought car a year ago and only covered around 9k (covid). would you suggest this is a good starting point?
i've seen gearbox oil levels suggested but find it odd that only reverse is the issue?
The mulitronic should be serviced every 40K miles, if that has not been done then it's the first place I would start. If that does not fix the issue then the only option is to remove the box and inspect.
to close this off for anyone interested in future searches, my mechanic / garage drained the oil and replaced with new. he saved me a bottle as a souvenir, it was thick black and almost sludgelike. there was a little drama involved in recalibrating the system but £300 odd later the problem is solved.
get the oil changed as advised!
Reactions: Pee Jam
