Suspension height for 1BV code.
John Wr
East Yorkshire
My SE 3.0Tdi Quattro C7 has been fitted with Eibach lowering springs and it is about to have work done on the rear suspension which will mean the alignment will need resetting.
To help me check if my vehicle ride height corresponds to build code 1BV, could someone please check their codes and if 1BV is applicable, please measure the ride height from the hub centre to the wheelarch at the front and rear wheels. The lowered ride height of my car is 370mm front and rear.
Thanks for any help.
John.
The 1BE S-Line Standard fit is listed as :
20mm lower then standard with stiffer spring and damper tuning for more direct contact with the road
The 1BV Option states that it is :
Lowered by 30mm with more firmly tuned springs and dampers for more direct contact with the road
Thanks Audidi, but I am trying to find a real world ride height for 1BV to compare to the ride height of my lowering springs.
John.
John.
Everyones measurements will be different due to age of vehicle, age of springs, how much use they've had, car weight, etc etc.
Reactions: Audidi
