AKE / BAU 2.5 V6 TDI Engine Misfire, Juddering, Diesel Knock
Mark-C
Age
southampton
hi all,
i have a misfire throughout all of the rev range and diesel knock under load causing lots of engine vibration and juddering. fault occured today whilst just coasting along on the motorway.
i was planning on replacing the cams in the near future as there was some noise coming from the OS of the engine and a leaky cam seal. im currently thinking it could be one of the rockers that have broken off so considering removing the rocker cover tomorrow to inspect.
ive recently replaced the alternator in the last week which i suspect had failed due to the amount of oil that is getting sprayed over it.
luckily i had my laptop and cable with me so i checked the measuring blocks on the injectors and checked pump timing.
cyl 1 and 3 injectors are measuring -2.5 mg/s at idle
cyl 4, 5, 6 are measuring +2.5mg/s
all values are way off, seems like one side of the engine is possibly compensating for the other?
i could not get a good reading on the pump timing graph, the timing for the pump was all over the place.
im guessing cyl 2 is the needle lift injector for which i didnt get a reading.
here are the fault codes that have come up
VIN: WAUZZZ4B15N023517
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 J
Component: 2.5l/4VTEDC G000AG 0006
Coding: 06006
Shop #: WSC 02334
VCID: 2C509C9FDC18905ED1-4A9C
Subsystem 1 - Part No: 00008059
Component: 130 106LC 106LCV79686256491256
WAUZZZ4B15N023517 AUZ7Z0D2675426
2 Faults Found:
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
16487 - Mass Air Flow Sensor (G70)
P0103 - 35-10 - Signal too High - Intermittent
Readiness: 1 1 X X X
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 N
Component: AG5 01V 2.5lTDI RdW 2222
Coding: 00001
Shop #: WSC 00000
VCID: 51AEED6B9BFA9DB682-5072
1 Fault Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D66
Coding: 06457
Shop #: WSC 02335
VCID: 4A9CFA0776ACAE6EC3-5000
1 Fault Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 M
Component: Airbag 8.4EP 1000
Coding: 0001106
Shop #: WSC 02335 785 00200
VCID: 59BE154B930AD5F67A-5072
No fault code found.
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 04460
Shop #: WSC 00001
VCID: 2D56919BE7029956C6-5072
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 X060
Coding: 25500
Shop #: WSC 12790
VCID: 4898C00F68A05C7ED5-5000
1 Fault Found:
01316 - ABS Control Module
79-10 - Please Check Fault Codes - Intermittent
End-------------------------(Elapsed Time: 06:47)--------------------------
after some reading up on the ross tech forum ive seen some people suggest a couple of these faults may have some connection with the two wire plug that connects to the alternator.
if anyone has experienced similar id greatly appreciate some advice on what you have found, thanks in advance
