Left Turn Signal Also Turns On Right Inner Turn Signal
Majid23
Age
42
USA
I have a strange problem on my 2015 A3: when I turn the left turn signal on, the right inner turn signal turns on. Everything else works normally. When I turn the right turn signal on, it operates normally. Any idea what could be causing this? Thanks.
I’m sure someone will correct me if I’m wrong but I think the older cars would send the voltage to another lamp if there was a blown lamp in that circuit. Have you check the back and side mirror lamps are working?
Thank you, I solved it! Leuchte17FL R BLK, etc. in the VAGCOM adaptation settings was the culprit. Lichtfunktion B 17 should say "nicht activ."
Reactions: KieranJ22
