Vag-Com Expert Help Required!!!!!!!!!!!!!!
mickpd3
Can my ecu be recoded with vag com NOT to communicate with the following controllers in the log below to prevent the fault codes(18053-18057-01324-01310)...Bear in mind that the engine and ecu were previously in a Allroad 4x4 and now in my A4 FWD..Engine type is A.R.E. These codes will not clear with vag-com and are a constant PITA...Thanks for any help guys.
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4Z7 907 551 B
Component: 2.7l V6/5VT 0003
Coding: 10812
Shop #: WSC 00535
WAUZZZ4BZ1N031770 AUZ7Z0Y1496807
2 Faults Found:
18053 - Powertrain Data Bus: Missing Message from AWD Controller
P1645 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08: Auto HVAC
Controller: 8D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 4Z7 920 980
Component: C5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00183
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
01310 - Level Control System Control Module (J197)
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End --------------------------------------------------------------------------------------------------
Oh swell, another one of these:
What do you have in Adaptation Channels 60 of the instrument cluster?
I'm rather baffled by the 18053 and 01324 codes since the Allroad has a purely mechanical AWD system and therefore should not have a control module for AWD..
-Uwe-
Hi Uwe. In adaptation ch 60,it say i have a stored value of 3201..There is nothing in the fields/boxes above.Four blanks... Apparently the allroad has electronic front and rear diff locks.Would this cause the faults???....Also in my last post i forgot to mention that i have a 5 speed fwd A6 gearbox,if that helps any....Thanks for your time and assistance. P.S.The car,engine,gearbox are all UK spec.
2 faults are now cleared.Thanks for that Uwe.Any ideas on the other two (18053-18057)?...If i can get rid of these,then the thorn in my side is completely removed.
Try coding the ECU to 10512, this should at least get rid of the AWD message. However, please keep in mind that not all ECU's support all possible combinations which means this ECU can be made for AWD only and won't accept FWD codings. Just for laughs, current versions of VAG-COM would give you detailed explanations for all these things automatically...
http://wiki.ross-tech.com/index.php/2.7l_T_(AGB/AJK/APB/ARE/AZA/AZB/BEL/BES)
No luck so far Sebastian.I try to input the new code,if im doing it properly (01-engine/recode-07/10512/Do-It) and it just reverts back to 10812. Do i need a WSC code as well, or do a log in to be able to change it?..If not,it indeed seems to be coded for AWD.Thanks.
