Day running lights error
Brandon093
Age
31
Cambridge
I recently changed my headlight bulbs to some LED headlights, when they come on, 1 of the day runing lights come on automatically and it gives me a warning light on the dashboard, has anyone experienced this before? and how do you get rid of it? All in installed correctly and no damages are done.. Thanks in advance..
LED’s have a much different resistance compared to a normal bulb, so the on board computer can get a different reading on the circuit and can mistake it for a broken bulb. Try changing back to the originals (if you can be bothered or have time) and see if the fault clears. If it does, then the LED’s aren’t suitable. You can either get the bulb checking circuit turned off, change the LED’s for a fault free version, switch back to the originals or make do with the fault!
Hope this helps!
