Rear wiper , wipes but no water?
Staceyf
Age
40
Hi
Any ideas for easy fix? It’s not end of the world the wiper moves as it should but no water but can hear it trying (same noise as wen you get water at front wipers) it did work then just stopped, and yes it does have water and screen wash in
Check for water in the boot, sounds like the pipe has come away and leaking. Failing that, blocked jet?
Oh yeah actually few months ago wen I had to use spare wheel there was water under it? So I just need to look for the pipe and reconnect it? Is it under all the plastic boot lining? (Sorry!) Thanks
Rear jet more than likely is blocked.
Take of the plastic cover of the rear wiper and take the plastic water jet off that, plastic cover just unclips and plastic jet just pulls off. Check if water comes out with it off. Easy 1 min way of checking if pipe has come loose or its a blocked jet. I had a blocked jet so just replaced it.
