Newbie TT MK2 Owner, looking for help with Bluetooth/Folding Mirrors
LebaneseMo
London, UK
Hi,
New to the forum and have only owned my TT MK2 3.2 V6 for a couple of weeks (I love it by the way), so new to Audi and new to the TT.
So far I have managed to figure everything out that I need to, aside from the Bluetooth and getting the side mirrors to fold automatically, so wondering if I can get some help. The Bluetooth is the really annoying and urgent bit I am trying to sort.
According to the dealer the Bluetooth module was installed at the factory and so should be OEM, however when I select "Tel" on the MMI it says "Telephone is not available" and pushing the "Setup" button while in the "Tel" screen does nothing.
I have tried scanning for the cars Bluetooth but I never seem to pick it up and I have followed the manual to the letter, ensuring I search for the cars Bluetooth within 5 minutes of starting the ignition (usually within the first minute or two), but nothing seems to work.
The MMI version is 0650, which I believe is RNS-E?
I also have the connector for the cradle in the middle arm rest, but no cradle, which apparently is normal and is also an indicator the Bluetooth module is installed.
I did a scan for fault codes and the results are pasted just below. Really hoping someone can help me figure out why this is not working and how to get it working. Do I need to somehow activate or enable it?
Any help would be greatly appreciated and if you now how to code it so the side mirrors auto fold, that would also be extremely helpful. Thanks in advance...
Scan Results (wouldn't let me include these on the original post for some reason):
Monday,29,January,2018,20:38:41:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 47 4C 52 55 56
77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 HJ HW: 022 906 032 GP
Component: MOTRONIC ME7.1.1G 0672
Revision: --H02--- Serial number: AUX7Z0G3FN403L
Coding: 0000178
Shop #: WSC 01236 785 00200
VCID: 5ABDE22A956813CEB59-800F
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 011 BL HW: 02E 927 770 AE
Component: GSG DSG 081 1397
Revision: 04508010 Serial number: 00000703200080
Coding: 0000020
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0017985
VCID: EADD32EAC508034EA59-80BF
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 S HW: 8J0 820 043 S
Component: J255 Klima 1 Zone 0060
Revision: 00H07003 Serial number: 00000001028706
Coding: 1049606
VCID: 3665569A413017AE711-8063
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 H HW: 8P0 907 279 H
Component: Bordnetz-SG H46 1802
Revision: 00H46000 Serial number: 00000006851753
Coding: F1061E8380141C0003180000180000000008EE075A250802
VCID: 428D3A4A1DF8BB0ECD9-8017
Subsystem 1 - Part No: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0060
Coding: 00064784
Shop #: WSC 01236
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00149804
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K0013662
Coding: 0011636
VCID: F9FF1DA6B0AEB8D65C3-80AC
Subsystem 1 - Serial number: 6332DRB4050D46ABW
Subsystem 2 - Serial number: 6342DRB4050CC5A1T
Subsystem 3 - Serial number: 63729RB4024062906
Address 17: Instruments Labels: 8J0-920-xxx-17-MY7.lbl
Part No SW: 8J0 920 980 C HW: 8J0 920 980 C
Component: KOMBIINSTR. VDO H21 0070
Revision: D0H21004 Serial number: 2243G004007304
Coding: 0049418
Shop #: WSC 00198 210 175874
VCID: 316F6586A85E3096243-8064
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010733002C0
Coding: FF0F03CA47004101
VCID: 2F6B63FEBE6A2666327-807A
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 96874 km
Time Indication: 0
Date: 2018.01.29
Time: 20:36:00
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
Address 25: Immobilizer Labels: None
Part No SW: 8J0 970 980 C% HW: 8J0 <20 980 C%
Component: KOMBIIKSTR. VAO H21 0070
Revision: D5H21004 Serial number: AUX2Z0G3FN103L
Shop #: WSC 00005 000 00000
VCID: 5BB3E72E9A52EAC6AEF-800E
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8J0 035 192 HW: 8J0 035 192
Component: RNS-E HIGH EU H10 0650
Revision: 01S Serial number: AUZBZ7G3502190
Coding: 0619717
VCID: E6C546DAD110272E811-80B3
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 96874 km
Time Indication: 0
Date: 2018.01.29
Time: 20:36:15
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J8 959 801 B
Component: Tuer-SG H02 0060
Coding: 0000565
VCID: 3C7144B27F1CCDFE875-8069
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 8J2 909 143 B
Component: EPS_ZFLS Kl.155 H07 1807
VCID: 30696082A354399E2BD-8065
Address 46: Central Conv. Labels: 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 9890300201182D298505489AD637
Shop #: WSC 12345 123 12345
VCID: 356751965C361CB678B-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000003846
Coding: 0246117
Shop #: WSC 12345 123 96591
VCID: 254781D6EC966C36C8B-8070
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 96874 km
Time Indication: 0
Date: 2018.01.29
Time: 20:36:00
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 HW: 8J0 907 274
Component: J502 RKA+ H04 0130
Coding: 0614100
VCID: EFEB23FEFEEAE666F27-80BA
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J8 959 802 B
Coding: 0000565
VCID: 3D7749B66406C4F6B0B-8068
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000024
VCID: 295F8DE6808E4856EC3-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H04 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH04 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0619717
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 96874 km
Time Indication: 0
Date: 2018.01.29
Time: 20:36:15
End ---------------------------------------------------------------------
Some additional information...
On VCDS...
- If I check the CAN Gateway install list "Telephone" is ticked but "Telematics" is not ticked.
- If I try to access module 77 is cannot communicate with it after several tries to do so.
- If I check the 37 for the Navigation unit and go into coding 07, the coding looks correct from what I have been able to decipher.
VAG Number: 8J0 035 192
Software Coding: 0619717
WorkShop Code: 00198
Importer Number: 210
Equipment Number: 175874
- If I check module 56 Radio the coding again looks correct from what I can see.
Welcome to audi-sport.net.
