Possible to install 2011 climatrocin to 2006 ?
IIRC the conclusion was that you can rewire/solder to get it almost working but you'll still be left with an auto button that works in reverse.
No, the can setup is different, it will stop working as only 1 motor will be driven as the other motor was replaced with a can plastic setup, wiring changes too.
You can hack the fascia to swap buttons but that's it, as I said, its not plug play working, so the answer is still no.
Also some parts of the heater system changed too, dash out job, trust me I researched this down to every detail.
