overheating?
karlabdool
Trinidad W.I.
Hi everyone,
My car is an a3 8v 1.8tfsi fwd (2014)model
Never had any issues with the car until today.
Started in the morning like I usually do, gave it a couple minutes to warm up like I usually do.
After about 10 minutes of driving i noticed the coolant temperature guage was about 2 or 3 blocks above the half mark (it never ever gets higher than the half mark).
I stopped the car, there were no leaks, coolant level was fine. Fans were coming on.
After letting it cool a bit I drove back home.
The strange thing is later in the afternoon I did another start and the car maintained the temperature at normal level with fan switching on and off. I let the fan cycle about 3-4 times and all was fine. Then i switched off and started back the car soon after and I noticed the coolant gauge begin to increase suddenly. It would go to the top with 1 more led block to go.
When it crossed the mid point i thought the fan would switch on to cool it, but it did not. I put on a/c to force the fan to come on and the fan did come on but temp guage did not drop.
I turned off a/c , then turned off car, then turned the car back on and the temp was right up (one less than highest LED) , this time the fans did come on and were blowing hard. But the temp did not drop.
I did a VCDS scan and this is what came up
Wednesday,21,June,2017,15:40:37:21429
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN: WAUZZZ8V8EA000845 License Plate: PCZ3923
Mileage: 36470km-22661mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F BB BC
VIN: WAUZZZ8V8EA000845 Mileage: 36470km-22661miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 0A251032240400083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
ROD: EV_ECM18TFS0218V0906264B.rod
VCID: 3B5BCBD2B2361599DA-806E
5 Faults Found:
15198 - Intake Manifold Flap; Bank 1
P2004 00 [096] - Stuck Open
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 16
Mileage: 35049 km
Date: 2017.03.28
Time: 07:30:38
Engine speed: 2145.50 /min
Normed load value: 22.4 %
Vehicle speed: 50 km/h
Coolant temperature: 78 °C
Intake air temperature: 31 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.808 V
Unlearning counter according OBD: 39
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 228 s
MAP_MES_SAE: 86 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.017 V
FAC_TPS_1_SAE: 21.875000 %
FUP_H_SAE: 19870.0 kPa
15200 - Intake Manifold Flap; Bank 1
P2006 00 [096] - Stuck Closed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 35978 km
Date: 2017.05.15
Time: 07:29:55
Engine speed: 4466.25 /min
Normed load value: 54.9 %
Vehicle speed: 52 km/h
Coolant temperature: 77 °C
Intake air temperature: 29 °C
Voltage terminal 30: 13.789 V
Unlearning counter according OBD: 14
STATE_LS_SAE[1]: CL
T_AST_SAE: 337 s
MAP_MES_SAE: 149 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 86.328125 %
FUP_H_SAE: 18660.0 kPa
17789 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 36461 km
Date: 2017.06.21
Time: 07:14:52
Engine speed: 1158.00 /min
Normed load value: 16.9 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 25 °C
Voltage terminal 30: 11.738 V
Unlearning counter according OBD: 40
Engine: operating status: IS
Engine temp. management actuator: raw value: 1585
Engine temperature management actuator: stop open: 144
Engine temperature management actuator: after-run stop: 3959
RVC_SP: 164.50 °
RVC_AV: 96.33 °
RVCPWM: -100.000 %
16464 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 36466 km
Date: 2017.06.21
Time: 07:32:20
Engine speed: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: 85 °C
Intake air temperature: 33 °C
Voltage terminal 30: 12.187 V
Engine: operating status: ES
Engine temp. management actuator: raw value: 1582
Engine temperature management actuator: stop open: 1582
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 5.75 °
RVC_AV: 106.06 °
RVCPWM: 100.000 %
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 36461 km
Date: 2017.06.21
Time: 07:14:53
Engine speed: 1084.50 /min
Normed load value: 16.5 %
RVC_SP: 75.73 °
RVC_AV: 96.13 °
RVCPWM: 100.000 %
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 E HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 3902
Revision: 00043014 Serial number: CU501304185753
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 P HW: 5Q0 907 379 D
Component: ESC H75 0434
Revision: 00000000 Serial number:
Coding: 12F18AA230200A6C037F060401C82948510C50C0608094B50059003885
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 49B7A11AE8EAB70958-801C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 HW: 5Q0 959 435
Component: VWKESSYMQB 021 0500
Revision: 00021000 Serial number: 0193300267
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 79D711DAF88AE78988-802C
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H09 0031
Revision: 20017000 Serial number: 00000000016016
Coding: 03100004100000000000000000000100
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 354FDDEA9412C3E92C-8060
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011312002025
Coding: 05011842C0C1027D03844000B31407A0080C000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 43ABB332CAC66D5992-8016
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130424 041 0580
Serial number: 130426123116
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0002
Serial number: 20114215
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Component: E1 - LDS MQB H05 0032
Serial number: 23 02 2013 00001686
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY130982Y6D
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000056638476
1 Fault Found:
262934 - Sensor for Anti-Theft Alarm System
U1138 00 [008] - Implausible Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 160
Mileage: 35996 km
Date: 2017.05.15
Time: 15:01:00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831312801038
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002015
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3753D7E28E1E31F93E-8062
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01DAA2
Coding: 98CCC000000000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BBB9B12E296A5196A-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 904 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000F44EC3D07
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 904 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000005B65D3D0%
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 104 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502BF0FBDE33C392
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 104 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502AB0FBDE30820O
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 403 13
Component: FrontSensor_D 001 6149
Serial number: 3556502A10FAE895817S
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 M HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 29041308491029
Coding: 8408
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 44A9B02ECFC86A61AB-8010
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 HW: 8V0 920 870
Component: KOMBI H24 0570
Coding: 278D0918238000080100AA00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 78D114DEC380FE81F7-802C
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 H HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1126
Revision: -------- Serial number: 0000569032
Coding: 010100F020085A005B0002081C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_008.rod
VCID: 364DDAE68914C8F125-8062
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528
Component: E221 - MFL H02 0014
Serial number: 29 04 2013 B1146254
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000074975003
Coding: 0900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73CB23F2DAE69DD9C2-8026
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 22041304081022
Coding: 001C9E205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3FA3BFC2A62E09B9F6-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D5FC5CAAC221BA9E4-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 21041303111312
Coding: 001C96205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E5DC2C6A12400B1FD-806A
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 039 0370
Serial number: A3E00805130689
Coding: 01730300FF0A000021220001001A00002F0001460100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 334BE3F29A66DDD902-8066
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG600U2L
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 C HW: 8V0 919 614 C
Component: ControlUnit_B H33 0037
Serial number: C1000005031300010116
1 Fault Found:
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 175
Mileage: 35794 km
Date: 2017.05.10
Time: 13:55:03
Voltage terminal 30: 12.6 V
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 20041302090423
Coding: 000C96204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 41A7B93AD0DA7F4980-8014
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 010 0006
Serial number: 20041303110404
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 03:26)--------------------------
The intake manifold flap faults were logged earlier this year so i'm not sure if they are related to the temp. issues that were logged today.
I appreciate your help very much as my car is just out of warranty.
karl.
Water pump internal valve not opening correctly when the engine has reached its warm up operating temperature.
It remains closed and doesnt allow the correct coolant flow.
Common vag issus, I had it on my octavia vrs
Thanks RSS , so are you referring to the thermostat ? Or the actual pump ?
The pump itself has a valve inside that remains closed when the engine is cold, to initially stop the full flow of coolant to allow for a quicker engine warm up.
When the engine has decided it has got to its comfortable temperature, the mechanical valve is supposed to open.
The pumps suffer with the valve either partially opening or not opening at all, causing a very slow circulation of the engine coolant.
Reactions: joshua arnison and Rob2k68
Good afternoon.
So recently i have had the same issue, did you just replace the thermostat? as if i look for the thermostat and housing online all i find is one with a water pump. i have had an email through from audi, and just for the part and the gasket they want to charge me £250.
so i ask could one of you please help me with what parts you would suggest to fix this issue.
many thanks Joshua
437
728
