Kinetix drilled discs + EBC Redstuff
Arkious
North East
Hello guys,
Looking at these discs to replace the my OEM rear discs;
http://www.ebay.co.uk/itm/251634024757?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
They are 310mm x 22mm which I believe to be the same as OEM but cant find the offset size, but as they fit the S3 id assume they would fit the RS3. I like them as the drill pattern matches the front discs and as I have brand new discs on the front, id like to take the opportunity to fit the new discs to the rear when I fit the EBC's.
So... my questions are, will they fit and are they any good as a disc in general?
MTEC drilled discs fit the RS3 and have a special coating to prevent rust. I have them on mine
Reactions: orac and Arkious
BLUEY's on MTEC and Redstuff, Jay, since January 2105 and the discs have stayed rust free:
Redstuff front and rear of course
Reactions: Arkious
DOH! thanks
When you speak with MTEC make sure you specify handed (drilled hole pattern) discs to match your STD fronts; double check the front discs jay and you'll find the holes are the same left and right: MTEC know this as I spent a lot of time talking to 'em.
Reactions: Arkious
Now that I know they don't go the right way, its going to annoy me like the rotor wheels do haha!
But thanks for letting me know, I called them to double check and they have put a note on my account. Cant wait to finally get the redstuff on, sick of black wheels and squeal at low speed lol
Reactions: 45bvtc
AND you'll be needing a short M14 spline x 1/2" drive bit, and a short wobble bar, to access the caliper support bracket; plus a piston wind back tool; otherwise straight forward: just sayin'
Tick Tick
Reactions: 45bvtc
pads and discs turned up today... and they put the wrong wrong disc type in after I asked them not too!
quick phone call and they are sending a replacement LHS disc so that the pattern matches both sides
Jay but it'll soon be sorted. Make sure you've a decent size breaker bar as them caliper mounting plate bolts are way tight; and again I needed a short wobble-bar to get full location in the bolt - upper or lower I can't remember but one of 'em for sure.
Reactions: Arkious
Yeah im going to give my mate a call to give me a hand, he has a better socket set than I do, plus an extra pair of hands cant go a miss
Unless they arrive on time it wont be this weekend they are going on now
Reactions: 45bvtc
10K
T-800
T
T
52
11K
