Facelift Window marks
mistac
Folks - I would like advice on how to remove the delivery sticker "imprint" from the windscreen (and rear window) - I only notice this when there is condensation inside - it disappears once the blower/air con is on but reappears every time it is cold inside the car! It is not residue/sticky but the imprint/shape of the sticker.
Also, I don't know whether I have not got the correct circulation flow setting, but I also note that the inside seems to "hhhh" up more than neighbouring cars after it has been standing still a while. Hopefully there is no damp/cold air getting in somewhere!
Reactions: Audi Bairn
Try some tar and glue remover or a glass polish. This should remove the imprint.
Reactions: allyboy
Is the "hhhhhhing" there after using the aircon?
I've still got the same three months in even though I've used glass cleaner on it. Though I've just had a light bulb moment. I only did in the inside!
Giving the car a good clean, dry and Hoover tomorrow so will report back if I've successfully get rid of the circles!
Meant to say I had already tried anti fog glass cleaner on all windows inside and out but no luck so far
Moister killer looks good! How long have you used it for? Where do you put it in your car?
I don't have it in the Audi, have it in the Fiesta though and a few friends have in there's. Works perfect in every one of them.
What about white spirit? Tempted to use that as really effective at removing stickers?
Spray a bit of WD40 on a rag and rub over the area. wipe off, then go over again with some glass cleaner.
Job done!
