- Joined
- Sep 21, 2009
- Messages
- 428
- Reaction score
- 153
- Points
- 43
S tronic DL501 takes around 730nm without hassle
I think they've held back because I mentioned the gear box limit to be honest
You really need to check the engine code on the engine itself.
That software you mentioned 8K5907311A - 0001 I don't have but i have a update 0002
Inside it tells me engine code is CLAB which is the 204hp
Can you ask them which file they put on the car?
Just out of interest @bobby singh , how well does the 204hp version respond to a good map ? Is the 204 simply detuned via the map its running, to provide a car that falls into a lower emissions / road tax band ?
Engine is same (almost) but main difference is turboJust out of interest @bobby singh , how well does the 204hp version respond to a good map ? Is the 204 simply detuned via the map its running, to provide a car that falls into a lower emissions / road tax band ?
Better than eastenders lol
Until we know engine code and turbo we really are just guessing.
I'm considering popping out of work now just to check
So potentially a software issue. But if it was as simple as a software issue, wouldn't the remap get above and beyond what it did?
(side note - where are those labels located please L80EWY?)
I'd have thought so too. Maybe we need to know what turbo it has just to be sure.
Please remove the engine cover and take a picture of the turbo.
Thats dpf.
The part number will be located on the turbo compressor side
I think you left your lights on L80EWY...
Click on my build thread and see picture #4
While you are out there take some torx screw drivers open the water box and pull the ecu out and take a picture.
Thats shown again in my build thread picture #3
Not that it means much but a reg check says it's the 245 model, maybe the dpf or egr is screwed, I'd definitely get rid of the dpf now it's mapped anyway else it's bound to clog.
