Flickering Lights and Alarm - HELP
Gavin Cooper
More power captain
BRISTOL
hi - i've just invested in the vag software as my car has been doing strange things - just wondering if anyone can interpret the following.
Any help would be really appreciated!
Thanks - Gav
Wednesday,13,September,2006,12:15:54
VAG-COM Version: Release 607.2-UD
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN Number: WAUZZZ8LZ1A072895
Address 01: Engine
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT 0003
Coding: 10710
Shop #: WSC 80185
WAUZZZ8LZ1A072895 AUZ7Z0Y1733349
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
Address 08: Auto HVAC
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0101
Coding: 00041
Shop #: WSC 06435
Address 15: Airbags
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 01104
Shop #: WSC 06435
Address 17: Instruments
Part No: 8L0 920 980 L
Component: AB-KOMBIINSTR. VDO D12
Coding: 01444
Shop #: WSC 00000
Address 22: AWD
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 16234
Shop #: WSC 06435
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
End --------------------------------------------------------------------------------------------------
was this the first time you scanned? I'd give them a clear first and see what comes back. Tbh the results are a bit inconclusive as you can see that the alrm has been triggered by a multitude of causes, and is also picking up on some suspected wiring problems and a dodgy central locking pump...
Thanks for the reply.
Yeh - i've already cleared all the codes once and they keep coming back. My car was broken in to by having the passenger window smashed and the sill bent by a screwdriver (ouch!) so I'm thinking it could be something to do with that?!
I envisage a trip to the stealership
I
3K
NHN
I
imported_gek
I
