Retrofit parcel shelf speakers
johnnevett
Oldham
Hi,
I picked up a full set of b&o speakers and started installing them today
I have all the speakers, sub and amp.
I have ran into a problem when changing over the parcel shelf speakers, I have no wiring for these.
Can this be retrofitted? Where do I need to wire them back to?
The part number for the speaker is 8T0 035 416.
I also need to know what size speaker cable I need and can someone help with the part number for the speaker connector and pins.
Or, are these speakers actually worth installing?
Any help would be great.
Any help on this please
To start, Does it need wiring to the head unit or the amp??
How's this?
Connectors for Bang and Olufsen soundsystem(MMI)
Digital sound package control unit -J525-
A - MOST bus
B - Multi-pin connector, 18-pin (T18b)
C - Multi-pin connector, 32-pin (T32h)
A - MOST bus
1 - Input
2 - Output
B - Multi-pin connector, 18-pin, black (T18b)
1 - Microphone input 1 (+) from microphone unit in front roof module -R164- (internal microphone -R74-)
2 - Microphone input 1 (screen earth) from microphone unit in front roof module -R164- (internal microphone -R74-)
3 - Microphone input 2(+) from microphone unit in front roof module -R164- (voice command microphone -R206-) up to week 44/08
4 - NF (+) (low frequency) from pre-fitted components for mobile phoneinstallation/Japan nav (up to week 44/08)
6 - NF in, right-side (low frequency) from connection for external audio sources -R199- (up to week 44/08)
7 - NF in, left-side (low frequency) from connection for external audio sources -R199- (up to week 44/08)
10 - Microphone input 1 (–) from microphone unit in front roof module -R164- (internal microphone -R74-)
11 - Microphone input 2(screen earth) from microphone unit in front roof module -R164- (voice command microphone -R206-) up to week 44/08
12 - Microphone input 2(–) from microphone unit in front roof module -R164- (voice command microphone -R206-) up to week 44/08
13 - NF (–) (low frequency) from pre-fitted components for mobile phoneinstallation/Japan nav (up to week 44/08)
15 - NF in, earth, right-side (low frequency) from connection for external audio sources -R199- (up to week 44/08)
16 - NF in, earth, left-side (low frequency) from connection for external audio sources -R199- (up to week 44/08)
17 - Open circuit diagnostic lead
1 - Terminal 30
2 - Terminal 31
3 - Loudspeaker (+), rear left
4 - Loudspeaker (+), rear right
5 - Centre mid-range and treble loudspeaker -R158- (+)
6 - Loudspeaker (+), front left
7 - Loudspeaker (+), front right
8 - Rear left mid-range loudspeaker -R105- (+)
9 - Rear right mid-range loudspeaker -R106- (+)
10 - Front right bass loudspeaker -R23- (+)
15 - Loudspeaker (–), rear left
16 - Loudspeaker (–), rear right
17 - Centre mid-range and treble loudspeaker -R158- (–)
18 - Loudspeaker (–), front left
19 - Loudspeaker (–), front right
20 - Rear left mid-range loudspeaker -R105- (–)
21 - Rear right mid-range loudspeaker -R106- (–)
22 - Front right bass loudspeaker -R23- (–)
23 - Front left bass loudspeaker -R21- (+)
25 - Subwoofer in rear shelf -R157- (+)
28 - Front left bass loudspeaker -R21- (–)
30 - Subwoofer in rear shelf -R157- (–)
That's great thanks
