I have a new Audi A3 S-Line Cabriolet with this engine and it feels flat at times. I previously had a 2013 Audi A3 1.4 S-Line 122 3dr and it felt quite a bit nippier. Better mpg too. Any thoughts ? I know the cab carries more weight.
I have issues with acceleration from standstill when stop/start isn't activated - needs a lot of pedal pressure to get decent power as the delivery is delayed.
When you get going it's not bad, but I suspect you notice the same delay as I do. I've done the ground work already - taken it to Audi etc. - it's normal...unfortunately. Switching to S / Dynamic mode helps.
My MPG isn't spectacular either. Other 1.4 COD cars get 50+ though the max I've hit is 47 driving gently - though I never use Eco mode.
I think the heavier body will dull the delivery of power somewhat in reading reviews, I can't see anyone describing the engine as dull though. In other models the 1.4 is a gem and very responsive...
The only time I have noticed the "flat spot" is when I've forgotten to switch from Eco mode when driving round town. I tend to keep it in Dynamic mode most of the time.
Here's my take on the settings for the 1.4TFSI COD engine
Auto mode- Never use it
Comfort Mode - Never use it
Eco Mode - Motorways and long stretches of Dual carriage way
Dynamic mode - everything except the above
Thanks all. I find it sluggish to pick up through the gears. I was in dynamic tonight and overtook a car in 4th. I found it slow to respond and almost bottled it. It feels like the car is going nowhere. Personally, I don't rate dynamic as the steering is way too heavy with very little feel. I'm happier with comfort. The car has only just gone 500 miles I might add.
Maybe use individual. Set steering @ comfort and the rest in "get out of my road slow ****!! I'm coming through" also known as dynamic. Not sure it'll solve your issue but it'll give you light steering and the quickest response
