misfiring fault, tech help needed - have vagcom fault codes
shufti
london
hi guys
i own a 2000 a6 avant 1.8T which has devoloped a misfiring fault. it generally drives on average at 30mph max with my foot to the floor with intermittent bursts of power that last no more than a couple of seconds.
can anyone help me in locating the problem, i can't afford to give it to audi so will try and replace the relevant parts myself once i know what is causing the problem.....
i've had suggestions of the maf filter or coil pack that could be causing this but these were suggested before i done the scan... i was able to arrange a vag-com scan today and this is what come back........
vag com - faults found......
17544 - Fuel Trim: bank 1 (add) system too rich - P1136
17536 - Fuel Trim: bank 1 (mult) system too lean - P1128
16684 - random/multiple cylinder misfirwe detected - P0300
16685 - cylinder 1 misfire detected - P0301
16687 - cylinder 3 misfire detected - P0303
16688 - cylinder 4 misfire detected - P0304
16686 - cylinder 2 misfire detected - P0302
17925 - main relay (j271) electrical malfunction - P1517
18010 - Power Supply Terminal 30: voltage too low - P1602
18034 - Power train Data Bus: missing message from TCU - P1626
17834 - EVAP Purge Valve (n80) open circuit - P1426
i called audi with the details of the main relay fault (17925 - main relay (j271) electrical malfunction - P1517) i thought that replacing this would be as good a place to start but after calling 3 dealers nobody could tell me what relay this is! anyone out there know????
thanks
thanks
no never changed the ecu, as far as i know it is original. i bought the car second hand and it was running fine for about 4 months before i started getting problems.
any suggestions?
you say 'i've had suggestions of the maf filter or coil pack that could be causing this' have you checked/changed any of them?? if not unplug the maf and see if it will run any better and see if you can borrow a set of coil packs from any 1.8t audi or vw
i unplugged the maf filter and there was a definate change in performance. seemed that the misfiring had gone and i had more power there but i had rough idling.
i will order a new maf tomorrow and see what change this makes before i attack the coil plugs
thanks for all advise so far, will post up findings
fingers crossed.........
it is unlikely all four coil will fail at once and i have never seen an ecu diagnose a coil with it still firing.
the rest of the faults indicate power loss so would be right to assume coils are also missing power feed.
summary yes sound like your main power relay, will be in the engine bay, usually housed withing a small 2" sqaure plastic box. have found usually a brocken wire between the relay and the ecu though as apposed to the actual relay.
HTH
