vag com fault codes..... any help out there please?????
shufti
london
hi guys
i own a 2000 a6 avant 1.8T which has devoloped a misfiring fault. it generally drives on average at 30mph max with my foot to the floor with intermittent bursts of power that last no more than a couple of seconds.
can anyone help me in locating the problem, i can't afford to give it to audi so will try and replace the relevant parts myself once i know what is causing the problem.....
i've had suggestions of the maf filter or coil pack that could be causing this but these were suggested before i done the scan... i was able to arrange a vag-com scan today and this is what come back........
vag com - faults found......
17544 - Fuel Trim: bank 1 (add) system too rich - P1136
17536 - Fuel Trim: bank 1 (mult) system too lean - P1128
16684 - random/multiple cylinder misfirwe detected - P0300
16685 - cylinder 1 misfire detected - P0301
16687 - cylinder 3 misfire detected - P0303
16688 - cylinder 4 misfire detected - P0304
16686 - cylinder 2 misfire detected - P0302
17925 - main relay (j271) electrical malfunction - P1517
18010 - Power Supply Terminal 30: voltage too low - P1602
18034 - Power train Data Bus: missing message from TCU - P1626
17834 - EVAP Purge Valve (n80) open circuit - P1426
i called audi with the details of the main relay fault (17925 - main relay (j271) electrical malfunction - P1517) i thought that replacing this would be as good a place to start but after calling 3 dealers nobody could tell me what relay this is! anyone out there know????
thanks
Hi there,
Its the Motronic current supply relay (J271) that your looking for.
Its located in engine compartment, front left, in plenum chamber, near
brake master cylinder.
The relay your looking for is the top right one.
I've got a file that shows you the location of this. If you want this PM me with your email address.
CHeers
Rusty
hi Rusty
thanks for that, not sure how to PM
is this where you mean?
i guess it's the black one.... 8d0951253a - does this relate to your file? email me the file if you don't mind - ed68@btinternet.com
cheers
Ed
there was supposed to be 2 pictures on last post, not sure why they didn't make it......
on the right of the ecu, 2 relays and one 40amp fuse
thanks
did you find the relay i have the same problem can you tell me where is that relay how does it look like please
