Coding door open beep sound
ROB A3 Quattro
no smoke without poke
You need to check "bit1 & bit4" to enable the beep when locking and the beep when unlocking
So to get to here you need to press "Select Control Model" on the home page
then press the Central Electronics Module -09
then Coding -07
then Long Coding Helper and ok the error that comes up.
Navigate to Component: BCM PQ25 on the drop down box
The go to Byte 5 and tick bit 1 & 4
Save the new coding and that's all did this today nice little mod
Reactions: Rideen
Is this to code it to turn it on or off? Is this the chime you get when the door is open and the ignition is on?
This is the coding so your car beeps when locking and unlocking on the key fob
