Audi A4 B6 Cab fault codes
vwnutant
manchester uk
Website
www.ukpassats.co.uk
After some help some of the below means nothing to me really !?....
Car- Audi a4 bfb 163bhp
remapped
k & n induction kit
rear boxes removed and new tailpipes
Five codes came up this evening - ( I did have the emissions light on presume that is lambda?)
AUDI A4 2003 BTB 163BHP ENGINE FAULT CODES –
DTC – SCAN
5 CODES FOUND 09/10/14
1) 17522-
17522
P1114
Heated oxygen sensor (HO2S) 2, bank 1 - heater resistance too high
Wiring, HO2S
2) 18010
18010
P1602
Engine control module (ECM) - supply voltage low from battery
Battery was disconnected, battery discharged, alternator, wiring open circuit, fuse
3) 16795-
16795
Secondary air injection (AIR) system - incorrect flow detected
AIR pump, AIR valve, AIR hose(s)
4) 18043
18043
P1635
CAN data bus, AC - no signal
AC control module trouble code(s) stored, wiring, matching resistor in ECM
5) 18058
18058
P1650
CAN data bus, instrumentation - no signal
Instrumentation control module trouble code(s) stored, wiring, matching resistor in ECM
Are the above common/anything to change/worry about ??
ive cleared the codes and will check again after work tomoz
Ant
the O2 sensor error indicates that the sensor needs to be replaced or the cat is on the way out and needs to be replaced. If you replace the cat you should really do the sensor too so I'd suggest replacing the sensor first and see how it goes before changing the cat
