Coolant Leak Has Come Back
Ste-Martin
S****horpe
Hello,
When I 1st got my car I noticed that it was loosing coolant every 300 miles and needed topping up. Could really see any leaks so thought it would be a internal issue. I put some Kseal in it to try stop it and it did for a good few months. Noticed today after topping up washer fluid that it has drank a bit of coolant. Might just put some more Kseal in it and see what that does or get rid as I
i'm not spending any more on it. It has just gone through MOT so they might of took a bit out of the tank as it was a bit over the max but I doubt it. Any suggestions? It has the C head in it.
Radiators are also a known issue for coolant leaks. They hold dirt/moisture in the corners which over time corrodes the rad and causes small leaks. Small enough to evaporate the coolant as it seeps out. Tell tale is pink staining.
I doubt they would have took some of the coolant from the tank.
Think I will stick some card under it when the weather improves and leave it for the night
566
704
NHN
512
TSM
808
