2013 A4 Radio removal
felto1
Hi all,
Recently purchased a 2013 A4 (Without Navigation) and was wondering if anyone knows how to remove
the radio from the car? I want to disconnect it from the car entirely without tripping
any theft deterrents. I understand that if you remove the radio you can trigger an
anti-theft system and then you have to bring it to the dealer to have it reset. Any info
would be greatly appreciated. Thank You.
I have to say I’ve never encountered anything like that when swapping radios and satnavs between cars.
So long as you know the 4 digit code when installing.
Radio goes into “safe” mode, and you use various buttons to enter the code.
I would countenance against using cheapo tools off eBay.
These ones (see picture) are too short.
I ended up buying a proper radio removal tool.
Sent from my iPad using Tapatalk Pro
Removing protected components does not cause any issues, it is when you fit a new/different by used protected component that you experience problems as the car will reject it and it will have limited functionality - with a radio no sound output - until you get Component Protection removed which is by removing the details of the original protected component and replacing with the new one's details, in the case of the different used one, it gets checked in case it is logged as being a stolen one, if okay it is changed back into being a virgin component and then added to the car's protected components data list.
Maybe you need to look deeply into this just in case you come up against some huge problems that will take big money to get you going with Sat Nav.
Edit:- one tip from my recent experience of just changing a Concert 3 radio for a Concert 3 with DAB, do not switch the ignition on until you have checked out your new installation as much as you can as it will operate okay until the ignition is switched on, then Component Protection will kick in for good or until you pay to get it removed.
Are you sure that what you wrote is still true for modern Audis, I think that you will find that Audi has been using Component Protection instead of PIN codes since B8 was launched.
As rum4mo says they now use component protection. I put my Concert radio back in my car after over 4 years and it worked with no issues.
