Heater only blowing warm
Coath
So , the first cold morning today so i decide to crank up the heater, it is only blowing warm air but gets hotter whilst driving at 60mph, temperature gauge reaches 90 fine.
I know the thermostat housing is leaking slightly, i have the new one which will be replaced shortly would this be having any effect ?
Coolant is g12
Does anyone have any suggestions where to start ?
Thanks in advance
Fix the leak 1st and maybe consider changing the thermostat at same time to discount this given you're in that area, if its not too expensive, then see if its improved.
I always work on basis if there are existing known multiple issues, they need resolving ideally 1st before looking for new issues not known of.
I read a few articles on various forums for things to check , so this evening I checked both inlet and outlet hoses going into the matrix, both are getting hot , I bled the system didn't seem to have any air in there , I did notice that the bottom hose coming from the coolant bottle is not getting hot ?
Would a faulty/leaking thermostat housing cause only warm air to the cab and hot air whilst driving at speed ?
Could it be the motorised flaps, if so how would I check these
I would say leaking stat which is stopping it warming up quickly.The flaps would prevent it giving heat at all speeds.Easy enough to remove the glove box and see if they are working OK.The temp gauge is not precise.Dodgy stats have been a bane of my decades of motoring.They don't seem to be any more efficient or reliable than 50yrs ago
One thing I forgot to mention is that last night whilst trying to bleed the system I had the coolant cap off to try and get rid of any trapped air, So I ran the car up and all was fine for a little while, but then the coolant level started to rise to the point it was over flowing from the header tank , Would a faulty thermostat cause this ?
I am going to replace the thermostat housing tomorrow , I hope this cures the problem
The system relies on the cap sealing tight to allow the pressure to keep the temp down.Same as you musnt remove the cap when hot cos it will throw hot coolant at you
