2005 PASSAT TDI STEERING TORQUE SENSOR FAULT
vw754
vorsprung Durch Technik
U.K
PASSAT TDI 2005 55 PLATE BKC ENGINE
got this code below.......however steering is working fine,just got the yellow steering light on..........Ive NOT checked the fuses yet.........What and Where is TERMINAL 15 ????
This happened after a flat battery,no other fault codes on the car....... (did full scan) only got the 1 fault: 00573 - Steering Torque Sensor (G269): Implausible Signal
CANT POST SCAN AS BATTERY DIED AFTER I READ IT ALL.........(CRAP LAPTOPS LOL)
Possible Symptoms
Steering Assist not working
Possible Causes
Steering Assist Power Supply (Terminal 15) faulty
Wiring/Connectors from/to Steering Torque Sensor (G269) faulty
Possible Solutions
Check Steering Assist Power Supply (Terminal 15) Check Fuse(s)
Check Wiring/Connectors from/to Steering Torque Sensor (G269)
Check Steering Torque Sensor (G269)
Possible Symptoms
Possible Causes
Possible Solutions
