Heater problem
Mr-C
UK
Call from Mrs C this morning reporting the heater are cold of the passenger side and warm on the driver side. She says she can control the heat on the drivers ide as per normal but regardless of what heat setting on the other side its cold from all vents on the side!
Obviously I'll do my Google/forum searches but before I search I'm putting this out there
Not that's I guess it matters but its a 07 3.0 TDI Avant
Have same issue with mine, except hot on passenger side and cold on drivers side, happened last night!!!
Sounds like the servo motor that controls the flap isn't moving.
VCDS will probably show a fault code that will identify which motor it is.
I had this, for the second time, a few weeks ago - turened out to be a dirty/corroded contact on the servo motor so I clenaed it and reeplaced it and it's all OK now - cost £0.00!
