HELP!!!! Car Not Starting After Coil Pack failure
C39KER
Audi TT MK2 With MSS Street Kit
London
Can anyone help me out!!!!
My forth coil pack burnout while driving which made the car come to a slow stop...I ordered the repair kit from Audi and got the mechanic to wire the new kit in. I replaced all four packs and connectors also.
All errors was cleared but the car is not starting, the ECU is still communicating with the car, all the lights on the dash are fine but the car will not firer up
Has anyone got and ideas why the car is not firing up
Have you checked the spark plug aswell?
New plug and coil packs have been added...do you think it needs to me reset by a Vagcom because we also notice that the coils are not sparking
Do you know where the circuit/fuse will be because i know on some audi have a fuse under the ECU
In order to verify the fuse point, you'd need to have engine & gearbox code to check within elsa.
After a next to a sleepless night a light turn on to one of my first thoughts....I said to my self that they must be a protective fuse if the pack melts and I was right. There is a 20amp fuse in the engine fusebox that went...replaced and all running well woo hoo
Thanks guys for you help
