A3 8L concert swap to concert 2 ?
basil brush
Chelmsford , Essex .
hi everyone , me and my better half both have A3 8L's both with faulty concert stereos tape deck ones .
what i would like to know is , would it be a straight swap to put an audi concert 2 cd player head unit in , if not whats involved ?
any help or advice would be much apreciated
baz
It's a straight swap but the concert2 uses the canbus to switch it on/off with the ignition whereas the older version has a separate 12v feed. So the concert2 won't switch on/off with ignition and will switch off automatically after an hour
hi andy , thanks for the reply , i have progressed matters in m own strange style i have bought a refurbed 3 month warranty concert to replace my knackered one along with a ipod connection unit BUT this has left my mrs who also has an 8L with stereo isuues annoyed (ha ha ha )
SO
hers is a 2001 facelift 8L , so i will ask the same question regarding her car , does the canbus issue still stand with her car ?
if this is so can i confirm that you can still turn the unit off manually without having to wait the hour for the unit to switch itself off ?
baz
Hers should be ok as they switched to canbus around 2000, but yes you can switch it off manually regardless
thanks andy , however the plot thickens ! I have today put in a kenwood HU and a known good audi concert 1 ! The kenwood works but no sound from the rear door speakers or boot mounted sub ( factory fit audi one) regardless of what I do with the balance or fader control , and the audi concert works perfectly with ALL speakers however is an inch to short of being wide enough for the aperture in the dash ! ( there's a half inch gap at either side of the concert which is already wider that a standard HU !
so is her car supposed to have some sort of audi din ( standard size HU ) stereo ?
If so what would it be ? I thought a concert 2 (cd) was wider than normal like a concert 1 ( tape type ) ???????
Baz
Depends what car the Concert came out of as they all have different sized over wide fascia's
The kenwood won't work with the rear amp/sub unless you have a PC9-404 adapter to link into the rear amp wiring loom.
