Rear wiper has to go...
CorrDogg58
How easy is this to do and what size bung do I need to fill the gap left?
i think there are caps for sale in classifieds section.
Is it easy to remove the wiper and what tools do i need?
because I have a few mates who had to cut it off
Take off the cap on the back wiper in the middle and use a 8mm or 10mm socket to remove the nut (cant rememeber the exact size) Use wd40 to loosen up the wiper then take your time and be patient to remove the actual wiper arm.
the will need to remove the 2 t25 torx screws from inside the boot panel and pull the boot panel off. Then it's a case of disconnecting the wiper motor and using the correct socket to undo the rear wiper motor.
Reactions: CorrDogg58
Thank you very much for this my friend. Do you know what size the whole is for a bung to fit into it?
my rear screen gets covered with spray on motorways +rain when stationary.
no way id delete the wiper.
why do want a rear screen covered with water?
