Parrot ck3100 into my A3 with sat nav
bonerp
Swindon Wilts
Hi
I would like my bluetooth fitting into my audi that has the sat nav unit (rnse?).
Is this a straightforward fit or a ****** to do that requires coding?
thanks
Is it a new ck3100 as it should come with its own looms/adapters.
Thats purely an iso to quadlock adapter which you may already have, ideally need to plum in with some repair wires into the quadlock properly.
are the repair wires the ones from audi (I think I read about them somewhere!)
thanks
Yes there are quite allot of different ones, but you'd need 000979009E's but you also would need possibly to solder the +/- wires to xisting rns power wires, unless as I advised before the ck3100 comes with adapters already.
I could do all this for you, iirc you wnated cruise done aswell.
I've got cruise on the car I ended up buying - well remembered tho!
Where are you based? I'm in Swindon wilts
Work all over the place, might have some work over your way at some point, PM me & we can discuss install costs.
