Audi A6 - Pressure good but no cold air
AudiLeon
Well-Known Member
North
Hi.
We have a Audi A6 2002 1.9 TDI 130.
When we got the car the ECON light was permantly on. I ran vcds and found a fault with the G65 sensor. Actually it'd been fully removed and the connection damaged. So I repaired the connection, fitted a brand new G65 sensor and had the system recharged.
It then turned out that the clutch ( I say clutch but it doesn't have one as it has a N280 valve) was missing. So I got a new plate for it so it actually did drive the compressor.
With VCDS I see a pressure increase with ECON being turned off and when I turn it on the pressure decreases. But I do not think the pressure goes up enough when the aircon is activated. My A4 goes to 9-12 bar when using aircon. Where the A6 barely hits 5 or 6.
I have run the car for 3 minutes with aircon on, both sides on LO.
I get:
A/C Valve (N280) Current: 0.650amp
A/C Valve (N280) Duty Cycle: 64.5%
High Pressure Signal (G65): 19%
Refridgerant Circuit Pressure (G65): 4.6Bar
It seems low, but the actual pressure is fine.
Could this be the N280 valve not opening enough to let the pressure build?
Well after the huge amount of suggestions.
I did something I didn't want to, i bought a top up can. Charged it up and it's working perfectly.
Hiv
Sorry to bring bring up this old thread. I have a very similar issue. My pressure is always 4bar regardless whether the aircon is on or off. Is that your case?
I can't remember now sorry bud. I had tons of aircon problems with that car! lol
