Brazil S3 thread progress
rmpreto
Brazil
Hi fellows, I decide to start one thread showing the progress of my s3. (I had showed it here in past but now I will take more serious the up grades and the post follow up)
So it is a 2001/2002 AMK silver s3, it has only 70000 km on it. My goal is to use it on track day but also keep it comfort to use on weekends without wife complaining! Hahah
So far the mods are:
Forge intake hose
ebc yellow stuff pads
madnex 3" stainless steel catback
advan neova tires
Next thing coming:
Liquid gauges
Remap
Here are some pics:
I hope to reach 260 hp after remap, what are your thoughts? Easy to get it?
nice tidy car.
what does the exhaust sound like? looks good.
if the car is healthy then 260 might be possible, depends who tunes it and how far they go. any filter upgrades?
get a jetex on there for the remap. a badger5 Intake pipe would massively increase your chances of 260hp.
i imagine its very hot where you are alot of the time.
heat kills power over here with a generic remap so it will be worse for you. consider a FMIC, expecially if you want to use it on track
Thanks! Have a video of the exhaust, but it was not good quality I set the go pro wrong:
[video]http://m.youtube.com/watch?v=3uXQozxuA9U[/video]
About the badger I thought this forge inlet pipe would solve, this is what I have:
Forge Motorsport | Alloy Fabrication
My car never runed hoter than 90c, but I see your concern I will think about the FIC!
Thanks!
Reactions: Pedrosousa
Looks well,like the twin of mine it looks a really clean car,is that an alcantara steering wheel? nice!
Thanks! the steering wheel is alcantara, I order the alcantara from e-bay and had a guy in Brazil replacing the leather. It feels 100% better, looks great! Plus it is very functional at track day wearing race gloves!
thank you
thank you
It looks really great,any close up pics of the steering wheel?
Steering wheel looks brilliant.
As Karl said, a FMIC would be a good idea. When you said you've not run hotter then 90 I assume you mean the coolant temp on the dash board? This will get over 100 on the road and track but the actual gauge doesn't move.
When you get a liquid gauge fitted you'll be able to see what you're inlet temps are. These will get very hot on track with standard side mount intercoolers.
Westy, first I have to say that your thread is awesome and very useful.
I see your point about the FMIC, makes sense. thank you
[video]http://m.youtube.com/watch?v=dKQ39MWPwNI[/video]
While the next upgrade and progress are not done, please watch my video from last track day, I think it is a decent performance for an OEM car.
Hi , one of the changes I made to my car was to instal one plug and play catback system, I got a Magnex piece (I see that most of people here for for miltek). To be honest I like the exhaust, easy to instal sound good, video is above, and price was good!
Here are more detail pictures:
Is that less efficient than miltek one?
Hi fellows just arrived new parts looking forward to install them
Liquid gauge
Hella super ton horn
I bought a set of volk rays and to install it I will use lug nuts and spacer
To give an idea of the wheels here is a picture
One question my intention is to pay the wheel in mat withe, shoul I do it or keep it gold?
Cheers!
not gold its no a Subaru.. its an Audi so keep it nice and classy
I just fit my liquid gauge, and it is as good as all review say, really worth it!
But after check few number I think I have a problem, they are:
Turbo boost 1.4 bar or 20psi
Engineer power 225bhp (mine is an AMK)
Intake temperature 68C
So I think everyone was right, the FMIC is necessary, but what is scaried me is the boost with such amount of boos I. Should have more bhp?
thoughts?????
the liquids bhp is calculated from the airflow. i bet if you log airflow in vcds it will equate to 235hp.
so its possible your maf is a tad under reading, worth a clean and/or new one. or use someone elses off another 1.8t.
thats my theory anyway.
So I believe, that the expected would be 235 hp, wich is nice! Can you guys tell me the Torque peak? (I forget my real number but it was either 33nm or 35 nm)
In other to investigate were is my 10 bph missing I will check for any leak as Westy suggested, and install a new MAF. I think it is a good stating point! Thank you all!
Hi all!
I did remind that liquid gauge can read VAG errors, so today I did check it out, here is what I found:
17526
17704
17608
17522
So what are your thoughts? I never had any contact with VAG faults before, is it bad?
Thank you
From Ross-Tech: Home
[h=2]17526/P1118/004376 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit[/h] [h=4]Possible Symptoms[/h]
  • Malfunction Indicator Light (MIL) faulty
[h=4]Possible Causes[/h]
  • Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating faulty
  • Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating Circuit faulty
[h=4]Possible Solutions[/h]
  • Check Wiring/Connectors from/to Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating
  • Check Oxygen (Lambda) Sensor Bank 1 Sensor 2 Heating Circuit
[h=3]17704/P1296/004758 - Error in Mapped Cooling System[/h] [h=4]Possible Symptoms[/h]
  • Cold start issues
  • Coolant Temperature Sensor (G62) faulty
  • Coolant Thermostat faulty
  • Check Coolant Temperature Sensor (G62)
  • Check Coolant Thermostat
[h=4]Special Notes[/h]
  • Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
    • Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
    • Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
    • Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
[h=3]17608/P1200/004608 - Boost Pressure Control Valve (N249): Mechanical Malfunction[/h] [h=4]Possible Symptoms[/h]
  • Malfunction Indicator Light (MIL) ON
  • Power Loss
  • Boost Pressure Control Valve (N249) faulty
  • Diverter Valve faulty
  • Check / Replace Boost Pressure Control Valve (N249)
  • Check / Replace Diverter Valve
[h=2]17522/P1114 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High[/h] [h=4]Possible Symptoms[/h]
  • MIL On
  • Faulty O2 Sensor
  • Wiring Harness Issue for O2 Sensor
  • Inspect O2 Sensor and Wiring Harness. See Repair Manual.
Doesn't look too major, but they do require attention IMO.
Change your lambda sensors, Change N249 valve, Upgrade DV to Forge 007p or 008, Change G62, Change Thermostat.
Re-run error code checking and let us know!
ha, change this change that. i admire your free will to throw away money.
check your lambda sensor wiring, may be a split.
have you done the n249 bypass? if not, do it. if you have, leave it electronically connected still.
is your car getting to 90degrees? does it ever read wrong?
Thanks a lot that was. Very complete reply!
At lambada I will check the wire if still neccassary I will change it (what is the part number?)
I will do the bypass, is there any "how to" here?
car never ran over 90 expected once that the fuse burn and Cooling fan didnt worked!
Thanks a lot!
Really nice car. I moved to Brazil and then moved back to the UK recently. I couldn't believe the prices of cars over there, it's mental.
For anyone that doesn't know, an S3 like that would cost you around £20,000 GBP in Brazil.
Where in Brazil are you?
cheers. ESCY
You are absolute right, the car here cost a lot more than in London, or Europe!
I am from Sao Paulo! Have you been here?
You don't need to change the N249 for the "17608/P1200/004608 - Boost Pressure Control Valve (N249): Mechanical Malfunction" fault... this is a symptom of an N249 bypass or DV fault... the fault code is thrown because the ECU has tried to dump boost using the N249/DV (which is what its there for) but hasn't seen the drop in boost its expecting so throws this fault suggesting there is a fault in the mechanism that allows the ECU to dump boost when it wants to...
If you have done an N249 bypass then it suggests you have problems elsewhere and this is symptomatic of that... If you have not done an N249 bypass then I would look at your DV... if the N249 was faulty I would expect to see open circuit/short circuit type fault codes specific to the N249
thanks Tuffy and all!
i am getting a little confused now! to be honest i think i don't know enough about what we are talking about, so i would like to request more explanation (sorry guys!)
First i would like to tell you what are my goals for the car regarding this bunch of tubes under to engine cover (i hate them and one of the is leaking air! may be that is the fault reason):
1st- i want by pass the N249
2nd- i want do a catch oil can also.
here are my questions:
what is DV? should i include this "DV" change to my list above? (i really prefer to have things upgrade, so even if it is expensive i may do it, if you guys agree that is a good change)
Should i just go ahead get my list done and run the vag com again and see if the errors are gone?
thank you all, i feel like i own the forum a lot!
do you know what and where the n249 is?
it is a small valve, combined with a small vaccum box and various pipes, on top of the engine, covers 1 or 2 of the coil packs which is a pain. the valve, as tuffty says, connects the dv to the inlet manifold.
the DV, diverter valve or dump valve, is what emtptys the boost system back into the intake.
with the fault codes you have, either of the two could be faulty.
this may help with the bypass of the n249 valve:
http://www.audi-sport.net/vb/a3-s3-...001-amk-car-bam-engine-if-makes-any-odds.html
as for the DV, most people will advise upgrading it to a forge 007p valve:
for reliability.
id do the bypass first, make sure the n249 is still connected electronically. and if you still have a fault that would indicate the DV is broke, which is likely with such an old part. id also upgrade the DV to the one listed, but if yours works, its not urgent, or essential until you start tuning.
thanks! i was following the bypass post made by tuffty, i think i will do it!
since i ma going to USA in couple weeks, i think i will take advantage of forge have a dealer there and order all forge stuff and replace my pressure hoses and also get a new DV. i hope it all fix my issues!
thanks a lot guys
Hi all! again I am taking your time to request help!
can you please tell me the part number for:
S3 MAF
S3 lambda sensors
Coolant temperature sensor (G62)
Coolant thermostat
thanks!
cheers. ESCY
Only to the airport. I lived in Joao Pessoa. There weren't any S3's up there. It'd always see them in SP and Rio when looking on Mercardo Livre.
Even A3's are a bit of a rare sight up North.
The car situation was so bad in Brazil, it was one of the reasons I couldn't settle.
you are right our cost of life and car are crazy!
thanks you
