Massive thanks to Rick @ Unicorn motorsport
outsideline
Lancashire
Any body thinking of having there car mapped in the coming future, give rick a call @ unicorn motorsport, very very noledgable guy and so easy to talk to......
we spent a few hours tonight tweeking the map rick wrote for me over the weekend, car goes like the clappers now!!!!
we deleted the dpf ( i removed it prior to the mapping work) and i have also removed all the egr, egr cooler and relevant pipe work.
Thanks for spending the time tonight with me and my motor, well appriciate it.
chris .
Where are they based and how much did it set you back in all?
Hi all,
in this case Chris removed his own DPF by gutting the internals. Works really well and gives a lovely turbo whistle.
For B7's, remap, DPF delete including modifying your exisiting DPF is £500 all in
We are based in Stockport, Cheshire.
Rick
as rick said, i removed the dpf from the car, cut a square secion out of the side of the original filter, knocked the internals out, then welded the square section i cut out back in. other than doing it on my back on axle stands its a fairly easy job.
I just had problems with the bolts on the filter closest to the down pipe, they all snapped off so i had to weld new nuts onto the filter where the pressed in studs used to be, but it made it much easier to put back.
also mines a quattro which didnt help.
