Disable Tyre Pressure Warning?
Burrsholt
East Sussex
Hi all,
Recently bought an S4 with non-standard alloys and the tyre pressure modules weren't swapped over.
Fundamentally missing the 4 modules so the tyre pressure alert fires up on the dash each time I put the car in gear.
Can I disable this with my VCDS or do I need to replace the modules and re-calibrate?
Many Thanks
That depends on what platform vehicle this is and which modules are installed. Post the Auto-Scan and the 10th digit of the VIN if you edit that out.
Cheers Dana,
VCDS Version: Release 10.6.4
Data version: 20110418
Saturday,04,June,2011,17:33:19:56338
Chassis Type: 8H - Audi Cabrio B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
65 67 73 75 76 77
VIN: xxxxxxxxx7xxxxxxx Mileage: 61040km/37928miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E3 910 560 HW: 4E0 907 560
Component: 4.2L V8/5V G 0020
Revision: --H01--- Serial number:
Coding: 0011774
Shop #: WSC 00672 785 00200
VCID: E5CBCD9A55F1
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 F HW: 09L 927 156 B
Component: AG6 09L 4,2 MPI RdW 0030
Revision: --H01--- Serial number: 4190602
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 2A51FEA6FC6F
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004902
VCID: 2E59F2B6C087
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00100
Shop #: WSC 00672
VCID: 6DDB35BA0D01
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 20021
Shop #: WSC 00672
VCID: 3D7BC5FA1DE1
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 E HW: 8H0 959 655 E
Component: Airbag 9.42 H09 1840
Revision: 92H09184 Serial number: 0037Y000GWGM
Coding: 0071114
VCID: 3C7DC8FE06FB
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 03141
Shop #: WSC 00672
VCID: 4183B90A6119
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 981 B HW: 8H0 920 981 B
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0007411
Shop #: WSC 00205 210 83714
VCID: 2F67EFB2C78D
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 A
Component: VSG B6 CABRIO 6894
VCID: 346DE0DE2EAB
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8H0 035 192 F HW: 8H0 035 192 F
Component: RNS-E HIGH EU H72 0500
Revision: 01S Serial number: AUZBZ7F1259125
Coding: 0419718
VCID: 2A51FEA6FC6F
3 Faults Found:
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 3
Reset counter: 94
Time Indication: 0
Date: 2005.02.10
Time: 00:04:33
Freeze Frame:
Voltage: 12.20 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 94
Time Indication: 0
Date: 2005.02.10
Time: 00:02:00
Freeze Frame:
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 90
Time Indication: 0
Date: 2005.02.10
Time: 00:00:45
Freeze Frame:
Mileage: 655350 km
Count: 206
Clock: 18:05
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00000
VCID: EFE7AFB2870D
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 K
Component: Komfortgerát T3B 5141
Coding: 06831
Shop #: WSC 00672
VCID: 3C7DC8FE06FB
Part No: 8H2959802D
Component: Tõrsteuer.FS BRM 0205
Part No: 8H2959801D
Component: Tõrsteuer.BF BRM 0205
Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
3 Faults Found:
01320 - Control Module for Climatronic (J255)
49-10 - No Communications - Intermittent
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3D7BC5FA1DE1
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0419718
VCID: 2A51FEA6FC6F
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 94
Time Indication: 0
Date: 2005.02.10
Time: 00:04:33
Freeze Frame:
Voltage: 12.20 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 94
Time Indication: 0
Date: 2005.02.10
Time: 00:02:00
Freeze Frame:
Voltage: 12.20 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 90
Time Indication: 0
Date: 2005.02.10
Time: 00:00:45
Freeze Frame:
Mileage: 655350 km
Count: 206
Clock: 18:05
Address 57: TV Tuner Labels: None
Part No SW: 4D0 919 146 D HW: 4D0 919 146 D
Component: TV Tuner H04 0580
Revision: 01H04001 Serial number: 00000000015110
Coding: 0004030
VCID: 2A51FEA6FC6F
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H13 0010
Coding: 00005
Shop #: WSC 00065
VCID: 356BDDDA25D1
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022825
VCID: 2A51FEA6FC6F
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 11.80 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
VCID: 356BDDDA25D1
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120616
Coding: 0001124
VCID: 3261E6C6D4BF
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H21 0290
Revision: 00000001 Serial number: 00000000486286
Coding: 0011802
VCID: 3B7FCBE203F5
End ---------------------------------------------------------------------
TPMS is a Federal requirement for US light vehicles produced after September 1, 2007 including all 2008 and newer Model Year cars. I'm not sure what the regulations would be for this particular vehicle. For this reason, I must say that Ross-Tech does not promote disabling systems that are required by law but I don't know in this case...
This TPMS module appears to be a separate module, not an integral function of the comfort module like some vehicles. You may need to locate and unplug it, but try this first:
The Gateway Installation List is an internal set of adaptation channels in the 17-Instrument cluster. Read the value of channel 061 and remove 512 (TPMS) from the original value and save the new value to that channel. After saving that value, cycle the key and see if the light is still on.
If the light is still on, locate that module and try unplugging it or locate the fuse and remove power so it does not communicate any longer.
Thanks Dana - just tried this and its looking good!
The warning light hasn't appeared so will go for a proper spin tomorrow to see how I get on.
First time I've used my cable so took a while to work the VCDS software - many thanks for your help on this.
Hey Dana, just a quick follow-up to say many thanks for the info as the error is long gone after the changes you provided.
Many Thanks
Awesome! I figured you would have posted sooner if the outcome was bad ;-) Thanks for the update.
