Anyone had a clutch replaced on an S3?
SamiG
On Boost, ish.
Southampton, UK
I got a price from the stealers and they want £1,500 for a clutch fitted!
They tell me it's an engine/transfer box out job..
I find this hard to believe but thought i'd get opinions.
Anyone had thiers done and can give me some home truths LOL.
Thanks.
Im currently sitting at Midland VW and they are doing mine know clutch and flywheel change is costing £825 all done
Haha random, i saw it after i posted this, that will teach me to look properly first
Steve did they say anything about transfer box/engine out??
engine doesnt have to come out gearbox and transfer box do have to come out i think they quoted £550 for just doing the clutch but as mine has done 115k i thought it best to do the flywheel aswell
yeah they said it would have been fine but for the fact the gear box is off it might as well be done at the same time
Mine cost £900 last year @ 106k after the slave cylinder failed, this was for new clutch, flywheel and slave cylinder at TTS. Its not a quick job. Steve are you having the slave cylinder changed aswell?
mine was on 79K and was in a bad way, it had seen some heat
My flywheel had excessive play in it so had to be changed, my god thou the difference after the work was done was night and day, my clutch pedal was very heavy before the slave cylinder failed but was so light after all the work had been done.
So i certainly should looking under a thousand pound to do the clutch/flywheel & slave cylinder then...
£500 at local garage about 12/18months ago. No flywheel though.
I did mine for £120 for a clutch and £49 for the slave cylinder, Took a full days labor but saved a whole lot of cash, Only extras were the fluids i changed while it was in bits. Had the box and transfer box off twice now and its a simple enough job if you have basic mechanical skills.
mine got done about 4 months ago by vw audi specialist cost me £200 for labour and £160 for the c&g fast road clutch,flywheel was not replaced got checked and it was fine.the car has 71k
