They might be a bit tight. I've just swapped my standard wheels with a 42mm offset for a set that are 45mm. There's no rubbing on the suspension uprights, but the gap between the inside of the wheels spokes and the outside of the brake calipers is minimal.
I am confussed now. Was looking up offsets on the internet and it is stated that its the difference between the hub face and the middle of the width of the wheel. So wouldn't a lower offset mean that the wheels sit further in??, not a larger one??
anything between ET43 and ET54 should be fine... some people run ET35, but those stick out so far that you're verging on it being illegal (rims sticking proud of the top of the arch).
