B5 Rs4 brakes under b6 s4 alloys on a b5 s4 anyone??
aidank1981
Shetland Islands
Been searching threads but this gets a bit specific! I have an rs4 b5 front brake set up BUT am unsure about clearances under a set of 18" s4 b6 avus 6 spoke's on my b5 s4, there ET45's and are pretty close to even the standard callipers!
Anyone running this? Can confirm if spacers are required and if so what size?
10mm spacers as a minimum. there is a guy on 246 that has them on his RS4 shod B5 S4, I believe he said you can just slide a rizla paper between them!
just missed out on a set of 18" avus wheels on eBay
The B5 RS4 calipers are quite a bit lower profile than the S4 ones, i'd recon they should go without too much of a problem.
