ABS G45 Front Speed Sensor - Fault
Watty
..... (_!_) Sarah's A3s #1 Fan
Perth, Western Australia
Been trying to sort out the ABS EPC lights on (A3 8P) in the dash for a few weeks and seems to be an electrical fault. Tried a new unit and error showed straight away without moving, so points more to wiring. VCDS still hooks up to the controller, so that should be ok. Does anyone know if the front right (O/S) loom from plug to controller is available and more importantly, what route it takes through the wheel arch liner to the controller, so I can rule this out before moving on to the next possible cause.
Speed sensor location, removed
Sensor
Through arch lining...
Part number label reads 1K0 927 903A
Comes through at A, but can't see it, then must arrive at B ???
Any idea's.........???
Thanks.
