Audi A4 b7 turbo a
What is a good bolt on/ turbo
    Votes: 0 0.0%
    Votes: 0 0.0%
  • Total voters
Harmeet
London
Hi there I’ve got a 06 b7 a4 2.0t
I wanted to upgrade the turbo with as few as possible mods.
what turbos do you guys recommend. At 220bhp at the moment. I wanna increase that as much as possible any help will be much appreciated.
There will be a set minimum of parts you'll need , also depends on what sort of upgrade you are thinking .
Easiest is a hybrid drop in kit that will just drop in , but you'll need a remap, FMIC and HPFP internals and HFC to go with it .
You could just do the drop in turbo with a remap but it wouldn't really gain much without the other mods , turbo upgrades on B7's is a very open ended subject and open wallet situation.
Then you'll need S3 injectors , uprated clutch etc etc....how deep are your pockets chap.
Agreed with above.
You could allways go with a decent remap, sports cat and fmic , that would get you around the 270 mark for a lot less than the cost of a turbo upgrade.
270 is still 50 more than 220 and a decent remap will make the car feel totally different.
Could you recommend me some turbos that’ll go in the b7 reasonable priced
They are all costly , but at the lower end for a drop in solution , but you will need other supporting upgrades would be something such as hybrids offered by BBT , after that it all gets a lot more costly , but depends on your budget really.
As you mentioned reasonable i'd look at BBT products , but you will need supporting mods to make any use of the turbo upgrade.
Turbo upgrade and reasonably priced don't go together very simple really either have 5k floating around or forget about it
Reactions: Charlie Farley
Reactions: TOM.S and Dan_Avant
I think all those options apply to our B7's to be honest, just a case of in which order.:yes:
I think my build would land somewhere in the expensive + good area. I’ve spent an average of about £1200 a year on engine mods alone over the 4 years I’ve had the car.
To answer the initial question, I’d look at Beach Buggy Turbos k360. Capable of 360hp with supporting mods (there’s a lot and they’re expensive). Turbo costs £850 if you send them yours to work on. More if you want one “off the shelf”
