Well it is that time again to give the old bus's interior a mid winter clean and that means fitted carpet and carpet mats.
I vacuum my old bus weekly and try to get as much sucked up as possible , nothing worse than a grubby bus really , well for me that is.
But how clean does vacuuming leave your old bus, well you may think after a good old session with the vacuum it will be spanking, it may look fine, but don't be so sure and you'll be surprised at how dirty the flooring gets even with regular vacuuming etc.
I spent a good hour this afternoon with my vax carpet cleaner doing all the fixed carpets and carpet over mats and this was the result after just doing the front.
filthy or what, the rear wasn't as bad as I don't normally have anyone in the back accept the woofer and has a big rug to lay on, but from the front it, it really makes you think.
Luckily my vax carpet cleaner with attachment sprays soapy water and then sucks it up as it goes so the carpets dry in 10 mins.
If you want to treat your old bus to one thing , give the carpets a good shampoo, it's makes all the difference,also cuts down dust in the cabin which can rise from the carpets.
Ok that's it for today, off for a cuppa now.
