ASB Upgrade to CDY
audifox
Berlin
Hey, I just finished the motor swap on my A6. Due to a defective head gasket, I had to broken pistons, I think I have driven to long with ist. So i build in a CDY engine. It’s the engine which is build in the facelift.
There are some things to manage, but the engine itself is plug and play. You need a feed pressure pump and have to build new fuel lines. The ASB has a fuel cooler which i had to get rid of. The cooling system changed a bit so there were some parts buyed new from Audi directly. The wiring was easy. I was really impressed how easy. I just had to use the CDY harness. You just need one cable from the harness to the new feed pressure pump and and one from the pump to (-). Also I needed a new ecu. The old is EDC16 and the new is EDC17. Adapted it to the immo and all was ok.
I had no dtc at all. I deactivated the dpf sensors and dtcs and after the first start I had no dtcs. Was really good, I thought there would be more work to do on the map.
Gearbox was also no problem, plug and play and still same protocol of the can bus system. It just has one problem, that some times at high loads, something is slipping after a gear change. I think it‘s mechanical, that the pressure to the clutch E can‘t build fast enough, there is a bearing that sometimes wears out. I think I will take out the gearbox next time and change all clutches and bearings plus the torque converter.
The problem occurs with stock map and tuning. Of course with tuning it’s more a problem. Maybe anyone had the same problem and know what it is? :)
4F56296F 77F2 47FE B324 CB2793BD84B7
3592E9E6 A94D 4407 BC35 3EF3EB1768BF
0614ED96 C8CA 4C3F 9B2C CB91728E9CD6
A926AE03 9997 458B 958E D8257F7C4F06
3392FD0D 7CDB 4A9F 95FD 7129E5F5C2DE
That's very nice work fella.. You should pat yourself on the back..
I have a question for you.
On the ASB the Y intake pipe is plastic and on the CDY is cast iron or aluminium.
Could you tell me if they bolt exactly the same way?
Because I want my ASB to have that intake pipe but unsure if it'll fit.
Thanks in advance.
Sent from my SM-N960F using Tapatalk
Hello!
The aluminum Y is bolt on when You change the inlet manifolds too.
Az én iPhone készülékemről küldve a Tapatalk segítségével
