Lowering struts
Paul battams
Active Member
As the title says what does anyone suggest to run on a A4 3.0tdi saloon 05 plate had some bilsteins on for 5 years but starting to sound a bit clunky and tired any recommendations plz.
Hi eibach springs 30 mm drop I think
Paul, i'm running Bilstein B8's with H&R 45mm springs and they are excellent, thought about changing to coilovers but decided to stick with the B8's as they work very well indeed with short springs.
Cheers rob
I’ve had mine on 4-5 yrs just wondered if there was anything better about looks like I’ll just replace 2 front shocks rears only been on 2 yrs as one failed
Reactions: Charlie Farley
Morning not bothered about going really low it sits nice as it is not really got a budget I tend to stop away from cheap stuff as been burnt before and end up buying twice maybe upto £1000 or do I need to pay a bit more???
Ive been in a similar predicament Paul.
I was originally just looking to lower my Avant for aesthetics only as the front arch gap was larger than i liked.
So the issue i faced was do i go coilovers or lowering springs and shocks?
Coilovers require you to spend a healthy amount of money for a good quality product that provide plenty of height adjustment and improved ride and handling. For me, i couldn't justify spending £500+ when all i was looking for was an aesthetic improvement. However i do believe that coilovers, should you buy the right ones, are the muts nuts.
So i settled for a set of Eibach Sportline lowering springs. Im really happy with the drop, it looks great, body roll feels slightly reduced over the stock springs and also it was far more cost effective for what i actually wanted to achieve.
Im now considered going down the route of Bilstein b8s. I feel in my case body roll and cornering needs improved slightly more, so for my budget, its a great alternative to coilovers. They get great reviews by b7 owners and are also reasonably priced.
Thanks for input Alex I’ve ran bilstein b8’s for nearly 5 yrs now I do like them just wondered 5 yrs on if there was anything out there that was better or worth the extra money
Cheers Paul
Reactions: AvantAlexB7 and Charlie Farley
732
12
755
501
